5 members (32Fordpuchoptop, 55shaker, TUTS 59, panel fan, UtahYork), 74 guests, and 0 robots.
Topics128,078
Posts1,055,940
Members48,430
#1057861 09/22/2014 6:38 PM
I have a push/momentary switch on the dash that I have no idea what it is suppose to work. In the back of the switch, it has two plugs, one plug with a light blue wire and the other plug with a dark blue wire and a black wire. Other than missing the knob, the switch appears original. For some reason, instead of the switch facing the driver they moved it and it faces down. Does anyone have any idea what this switch works?
Trace the wires...see what they go to.
What year truck?
What kind of transmission?
Can you post a link to a photo of the installed switch?
" . . . instead of the switch facing the driver they moved it and it faces down." How do you know the switch has been moved?
It sounds like you're describing the original-equipment starter button for a hydramatic-equipped truck. It was on the left side of the steering column, facing downward toward the floorboard on the rolled-under part of the dash.
"It sounds like you're describing the original-equipment starter button for a hydramatic-equipped truck. It was on the left side of the steering column, facing downward toward the floorboard on the rolled-under part of the dash. "
What year(s) truck, Jerry?
The poster has not specified a year.
The solenoid starter button on Hydra-Matic 54/55 trucks is not as described.
The 54 GMC I drove hauling hay for a neighbor back during high school had the starter button located as I described. It's possible it had been relocated, I suppose, although I sort of remember that location on a few others. 50-something years can play tricks on an old geezer's memory, however!
My truck is a 61 Chevy C10. It almost seems like the switch could be for the wipers with the push part being for the washers, but I already have a switch for the wipers and I do not have washers. I have been checking wire schematics with no luck.
