Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (dt235sd, Sjm), 99 guests, and 2 robots.
Topics128,283
Posts1,058,505
Members48,490
I need to update my speedo to an electric speedo due to the late model T5 I'm running. So I might as well update the whole gauge package. I don't want to buy a billet panel at 150.00. What have ya'll used?
Rick
for a '46? there are lots of good electronic speedos available, but doubt there's many that could be adapted to your dash panel, so you might consider one that could be mounted to the steering column .... but you might also get an adapter to convert the trans signal to mechanical for your existing speedo, number of them available
Moderated by  ndkid275, Phak1
