0 members (), 79 guests, and 4 robots.
Topics128,021
Posts1,055,373
Members48,420
#1058121 09/23/2014 9:32 PM
I am planning on buying a Sealed Power CS-293 Camshaft for some more torque but a smooth idle.
It is a 261 cubic inch replacement with more lift and duration than a 235 cam. They are new, not reground, and are only $99 at Summit. List is $238.
The matching Sealed Power solid lifters, #AT-874 are discontinued. Melling's are still available, #JB-874 (very similar part number).
The Sealed Power 874 applications are listed as fitting 55-62 Chevy 235 and 261.
The Melling 874 applications are listed as fitting 55-62 Chevy 235 and 261, as well as 194, 230, 250, 292, GMC V-6s, AND small and big block V-8s up to 1974???
Summit offers Comp Cams # 2900-1 solid lifters and Summit lists them as fitting 55-62 Chevy 235 and 261, as well as all the other engines that Melling lists, including the V-8s up to 1974.
O'Reilly auto parts lists the same fitments for the obsolete Sealed Power 874 of only 55-62 235 and 261, but for the Melling 874 it also lists the other 6s and V-8s.
Comp Cams itself lists the 2900-1 lifters as for V-8s up to 1974 but does not mention any 6s.
The dilemma is that some old stock Sealed Powers are out there, and the Melling's are available, but they vary in price from $14 to $25 each. That's $168 a set.
I'm sure the Comp Cams lifters are highest quality and made in USA, yet they are available for only $72 a set.
Does anyone know if the Comp Cams lifters will actually fit?
Thanks!
Any lifter that fits a 194-292, or V6, or V8 will not fit a 235.
My Blog
235 lifters are larger diameter and MUCH taller than V8 lifters. I think the 2nd-generation 6 cylinders might run a lifter that's similar to the V8's, but I'd have to measure one to be sure.
There are about 20 sets of NOS 235 solid lifters on Ebay right now, both the milk can shape and the later design ones that resemble the hydraulics. They're about $125.00 a set which works out close to $10.00 apiece. Not wonderful, price-wise, but they're certainly not hard to get.
Thanks, but those are all for 216-235 up to '54, mine is a '56 engine.
There are a couple sets of hydraulics and a set of "Falcon" mechanicals 55-62, but they're made in China.
I ended up finding the last 12 NOS Sealed Power AT-874
solids that Rockauto had, used a coupon and got them for $11.00 each.
My CS-293 cam is coming from Summit and I've locally sourced Sealed Power springs, pushrods, retainers and seals.
Thanks to everyone for their replies.
