0 members (), 108 guests, and 0 robots.
Topics128,115
Posts1,056,292
Members48,439
#1057829 09/22/2014 3:25 PM
When nstalling a 4 pce oil pan gasket set, do the two rubber end gaskets go onto the block first so that the cork gasket tabs lay over the rubber tabs or vice versa?
What engine are you referring to. 216 or ?
Drew
Side gaskets first. Push the ends in as close as you can to the main caps. I then put a dab of Permatex in the corners and then install the rubber ends.
My Blog
thanks dave
