0 members (),
170
Mod | | | Forums66 Topics128,081 Posts1,056,078 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2014 Posts: 14 New Guy | | New Guy Joined: Sep 2014 Posts: 14 | Hi All,
Hope I am in the correct forum and not jumping into anyone else's post.
My query is directed to specifically NP435 Transmissions, I have been led to believe that Chevy/GMC only used these particular tranny's between the years of 1968-1972. Were they restricted to the inline six (what size?), or also used behind the SBC engine? I also believe they came in two different ratios for GM/Chevy. Being over in Australia, these seem to be thin on the ground, plenty of auto's or the GM SM 420/465 available (with a bit of searching), but not too many of the NP.'s.
I was hoping to lay hold of one of the "close ratio)NP 435 (A) or even better, the NP435 (D) for a build up project. Trouble is I am not very well up on Chevy, but have always admired the C10/C20's and now that I have retired, wouldn't mind something to have a tinker with.
Hoping someone can throw a bit of light my way.
Cheers, Dave 64 | | | | | Joined: Mar 2010 Posts: 843 Shop Shark | | Shop Shark Joined: Mar 2010 Posts: 843 | Dave, The 435 has a "Granny" first gear. If you want close ratios the one to use is the 445. Its ratios are 4.56, 2.20, 1.31 and 1:1. I have one in my '71 Dodge van and it's perfect for towing a small travel trailer. Ray [email protected]
Ray
| | | | | Joined: Sep 2014 Posts: 14 New Guy | | New Guy Joined: Sep 2014 Posts: 14 | Thanks Ray,
May actually be onto one , supposed to look at 318 Dodge NP last weekend, bloke was working. Cheers, Dave. | | | | | Joined: Mar 2012 Posts: 211 'Bolter | | 'Bolter Joined: Mar 2012 Posts: 211 | Chevy's in the states used sm420 from 1947 till 68 and 1969 introduced the sm465 till 1987? Thought the 435 was a ford/ dodge thing | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | | | | | | Joined: Mar 2012 Posts: 211 'Bolter | | 'Bolter Joined: Mar 2012 Posts: 211 | Just going on personal experience, Having owned and parted over 35 67-72 chevy/gmc trucks, every 4 spd was a 465 or 420. | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | It is true that most will be 465 or 420's, but one of the 1969 Chevrolet one tons at a construction company I worked for had the NP trans, so they are out there.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Sep 2014 Posts: 14 New Guy | | New Guy Joined: Sep 2014 Posts: 14 | Hi, been trying to find a bit of info on the NP445 as suggested, reckon that is about the ratio I needed. Mate of mine has a Dodge 4 tonner sqirrelled away in his yard, been underneath it to get some numbers, don't match up with anything I have. When I get back home will probably have to jerk it out to get a decent look.
Seems to be a little conjecture about GM Chevy using a version of the NP435's. Novak list them, but appears that if they were used at all, it was very sparingly in Chevy, as from what I am reading here, most were fitted with SM420 or the later SM465's.
Very hard to source a GM Chevy NP435 over here in Australia, been posting messages on different forums for some time, so far unsuccessfully.
Cheers, Dave 64 | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | GMC used a lot of the NP 435 transmissions. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Feb 2004 Posts: 29,795 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,795 | I've got one stashed away up in the barn- - - -no idea what vehicle it came from, but it's got the GM bellhousing bolt pattern and input shaft. Jerry
| | | | | Joined: Sep 2014 Posts: 14 New Guy | | New Guy Joined: Sep 2014 Posts: 14 | Thanks Guys, Looks like they are still around, but so far no luck over here in my country. Will keep asking around, may turn one up eventually. Thanks. dave 64 | | | | | Joined: Jun 2012 Posts: 1,747 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,747 | Pulled a NP435 out of my old 1967 3/4 ton. It had some very bad synchros in it. The parts were easy to replace but costly. If I had a less informed parts guy I would have had the wrong parts in hand. I would think the internals would be available from a Ford parts supplier. The case with the GM bolt pattern, would be the only difference. Truck type 4 speed with a very low 1st gear.
Steve H
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The early ones had a weird syncro setup. They didn't last very long. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: May 2014 Posts: 23 New Guy | | New Guy Joined: May 2014 Posts: 23 | I tore apart a 68 GMC 6000 today. It had a 292 and np435d. | | | | | Joined: Sep 2014 Posts: 14 New Guy | | New Guy Joined: Sep 2014 Posts: 14 | So, anyone remember anything about these NP435D's ?? I had been told they used the close ratio all synchro boxes in SOME 1968-1972 camper vans and some school buses as well. Trying to find out if a 22 tooth input shaft and input shaft housing still obtainable. Thanks, Dave 64 | | | | | Joined: Sep 2014 Posts: 14 New Guy | | New Guy Joined: Sep 2014 Posts: 14 | Think that should have read NP435A Daven 64 | | | | | Joined: Sep 2014 Posts: 14 New Guy | | New Guy Joined: Sep 2014 Posts: 14 | Got that wrong as well! Should read NP435GA Dave 64 | | |
