| | | Forums66 Topics128,139 Posts1,056,454 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2014 Posts: 20 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2014 Posts: 20 | Has anyone looked into doing an axle swap with a Dana s110 or an s135. these axle are found in new ford f550. our little bucket trucks at work are f550 I'm gonna measure one of them today see if axle are about the same width as my c50. but didn't know anyone else had looked into these axle | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Does the F550 have a smallish 10 lug bolt pattern that is only used on the F550? Are you OK using those wheels or do you need larger ones? Are larger ones available? Rear axles are real easy to swap in this size truck and most any axle you look at and think might fit will fit quite easily. So find an axle from any application that has the type brakes you want, axle gear ratio, and wheel mounting/bolt pattern to suit. Don't swap an axle in because it's an easy swap but then has undesirable features. Here are some pictures of an axle swap I did on an F350 a few years ago. Used a Meritor 12 or 15,000 lb axle from an 05 Freightliner medium duty of some description. It was a new take out with suspension and all, just drilled holes in the frame to bolt it in. It had the large disc brakes I wanted, came with a used pumpkin with 3.73 gears which I wanted, and modern 8 lug hub centered hubs with easy to find 22.5" wheels (matched the front axle I swapped). https://picasaweb.google.com/lh/photo/WTayjrbZBVsYOtZbQEyGq9MTjNZETYmyPJy0liipFm0?feat=directlinkhttps://picasaweb.google.com/118082...esel6V53T?authuser=0&feat=directlink | | | | | Joined: Jul 2014 Posts: 20 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2014 Posts: 20 | that's basically what I'm after is a higher gearing so I can get little more speed and be able to get a more standard wheel. so I don't have to go on a wild chase trying to find wheels. and to also have disc brake. but only thing I'm having little trouble doing is finding the same axle width that I have now. so the truck still looks more original | | | | | Joined: Jul 2014 Posts: 20 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2014 Posts: 20 | also what kind of highway speed are you getting out of you 48 Chevy. I'm looking at a lot similar setup on my 65. I would like to get a normal highway speed 65 70. without feeling like the truck gonna fly apart | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | The 48 is not yet on the road, well it is licensed and I've driven it around but nothing more on it yet than a cab with doors. It also only has 4.56 gears at the moment though I have a set of 3.54 to swap in. It should be comfortable at 80 in Overdrive if I wanted to try it, or 65-70 in direct. Calculate RPM and speeds given tire size and axle ratio here http://www.onlineconversion.com/bigger_tires.htmJust because the calculator says you can doesn't make it so; you may not have enough engine to pull the truck along and push the wind out of the way at high speeds. Grigg | | | | | Joined: May 2013 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: May 2013 Posts: 66 | I'm doing a Dana 80 swap from a '00 Chevy HD3500. I'm NOT a master mechanic and am trying to do it and it's going OK so far (other things are getting in the way) Also trying to get the front solid axle under my '64 2-ton stake truck. BUT, the tag is showing a 5.13 gear!! I wanted to install a Allison 545 but that doesn't have an overdrive.
Anywho, it's in my 'dustlessblasting' business build (to use as a rolling testament of what the blaster can do.
PM me your number and I'll try and answer questions if i can.
Errol | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | D-80's can have up to 3.54 gears,carrier swap, reqd. The solid front axle from the HD 3500 can fit, check spring pad dimensions- spacers can be made to correct for smalll discrepancies- see Grigg. Probably can use the Saginaw steer box and pump from the 3500, might have to remove skip spline from arm, change steering from side to side to fore and aft-just remount the box. While you're there , get the Hydroboost.
| | | | | Joined: Jul 2014 Posts: 20 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2014 Posts: 20 | I like the thought of Dana 80 for parts availability. but I want a big looking axle to make still look somewhat stock.And I want one with a 3rd member axle. the front I'm gonna keep my eye out for a 3500hd. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | The 3500HD axle has a Y type draglink and tierod, in my opinion not as easily adapted to these old trucks. The 5/10 lug I-beam axle from a P30 chassis has draglink and tierod like the old truck, easier to adapt, and in all other aspects is like the 3500HD axle.
The Dana 80 and P30 or 3500HD axle combo are good for a vehicle GVW of about 14,000 lb judging by the rating of the vehicles they came stock in.
A Dana 80 can be had with 3.31 axle ratio, or gears can be bought for it. The carrier split is 4.10 and lower numbers use one carrier, all higher numbers use a different carrier. The split on a Dana 70HD is 4.56. | | | | | Joined: May 2013 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: May 2013 Posts: 66 | I did a little searching on the 'net' and it looks like quite more of a challenge to set up a Dana 80. I really don't mind the 5.13 since I'm going with a tire that's almost 46" tall (445/50 R22.5) Super Single. In my application I don't expect to be running over 60mph, and i can wait for another gear and carrier.
Are You using your "stock" steering box? Is it non-power or power?
I got a power box from a GMC school bus to run my Hydro-boost, but MAN.. That hole for the pitman arm looks B I G compared to my little hd3500 center-link tie rod end.
Is it possible to post pics? I'm going to try and compare to see if just MAYBE the spindles can swap on the orig axle beam. I'd like to see what you've got since I've got a '64 C50.
Errol
| | | | | Joined: May 2013 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: May 2013 Posts: 66 | I'd kill for a lathe and 5-jaw chuck like that in your pics.. (well, almost) That and a CNC overhead mill too!
side note, Grigg where did you get your 4-53t from?
Where did you get your Dana from?
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I found one 4-53T in a 1978 GMC 6500, bought the truck on ebay and drove it home, then pulled the engine and parted and scrapped the rest. Another 4-53T came basically new as military surplus though I was a few owners after originally surplussed, picked it up in Texas. And another came from a skidder.
The Dana 70HD in my 2 ton came from burnt RV with a GM P30 chassis.
Grigg | | |
