3 members (Phak1, Otto Skorzeny, TexasA&M48Truck), 110 guests, and 1 robot.
Topics128,092
Posts1,056,040
Members48,433
#1056927 09/18/2014 1:05 AM
I'm curious if any one else has had trouble with YF carbs. I have not disassembled it but it appears the float is stuck. I rebuilt it 700 miles ago then the truck started to hiccup. Now it won't start and I don't hear gas being pumped into the manifold when I pump the acc. The fuel pump is pumping. Are the Rochester's better?
GWWirth #1056939 09/18/2014 1:43 AM
If you have fuel in the bowl and don't see a squirt of gas when you goose the throttle, you likely have a bad accelerator pump diaphragm or trash is blocking something in that vicinity.
52Carl #1056950 09/18/2014 2:11 AM
Thanks. Yeah its just frustrating as I rebuilt it only a few miles ago and she was running great. Oh well might be a stuck float. I,ll add it to my todo list.
GWWirth #1056951 09/18/2014 2:15 AM
Have you checked the inside of your gas tank?
Yeah I had it bead blasted out and recoated. There was some larger particles in the fuel pump. Could be just the restoring pains of the first few months on the road. I expected some issues. Now the right front shock started leaking. I just need to take a break from the truck.
