7 members (Donf, JoeDude, 48jim1ton, gswbbc, frogfarmer, Gdads51, Gib70),
109
Mod | | | Forums66 Topics128,035 Posts1,055,528 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2011 Posts: 266 Shop Shark | | Shop Shark Joined: May 2011 Posts: 266 | I guess all the motors are pretty much the same. I have l,h,p,b on the switch. My motor wires are yellow,white.green, red. l=low,h=high,p=park, b=?. what wires go to which terminal on the switch? I also have a fused red (power) wire and ground (black) I know where they go. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I'm sure all wipers are not the same. Is it after market or recycled from another vehicle? Or stock for your vehicle? What is your vehicle? | | | | | Joined: Jan 2011 Posts: 306 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 306 | if its a Newport motor, which by the wire colors sounds like it. go to the Newport engineering web page. they have the connections there. I know green goes to p(park),red goes to the b(power), I believe yellow goes to l(low spd) and white goes to h(high spd) but don't trust me. go to the website.
rolf
1963 c10 | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | What is your wiring harness from or who makes it and same for your wiper? | | | | | Joined: May 2011 Posts: 266 Shop Shark | | Shop Shark Joined: May 2011 Posts: 266 | electric wiper motor from LMC.The wiring has nothing to do with the harness. The issue is from motor to wiper delay switch. sorry for the confusion. 51 chevy 3100 as stated previously I guess all the motors are pretty much the same. I have l,h,p,b on the switch. My motor wires are yellow,white.green, red. l=low,h=high,p=park, b=?. what wires go to which terminal on the switch? I also have a fused red (power) wire and ground (black) I know where they go
| | | | | Joined: May 2011 Posts: 266 Shop Shark | | Shop Shark Joined: May 2011 Posts: 266 | Here ya go young man !!! L= yellow H= white P= green B= red | | |
