| | | Forums66 Topics128,168 Posts1,057,025 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2012 Posts: 101 Shop Shark | | Shop Shark Joined: Oct 2012 Posts: 101 | finally ready to put on exhaust !! cant find a diagram or image how to best have the muffler shop make me peices. cant drive it there tires to rotten. anyone know of photo or diagram how to run it. thanks | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the 55-59 Factory Assembly Manual shows the exhaust layouts for different models, you need to use some coat hangers made to the shapes needed on your actual truck so the shop has dimensions for the bendy parts .... the main things will be the shape/length of the head pipe [manifold to muffler], the inverted U over the rear axle and lengths from muffler to the axle and axle to rear exit .... the muffler was positioned under the bed where you should have found a metal plate that was a heat deflector for it
Bill | | | | | Joined: Dec 2003 Posts: 1,061 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,061 | If you are ging to have someone bend it for you, check and see if they or somebody else has the specs. I lucked out when a local place just checked a reference and plugged in the numbers. I had the pipe in about half an hour. A guy in a glass shop told me he had glass dimensions for my 46 as well.
1946 1-ton Panel 1952 1-ton Comml. W/Grain Body | | |
