7 members (ShopRag, KEVINSKI, Peggy M, Otto Skorzeny, Hotrod Lincoln, 1955 1 Series, 69Cuda),
152
Mod | | | Forums66 Topics128,267 Posts1,058,373 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#10560 04/21/2002 8:29 PM | Joined: Mar 2001 Posts: 1,181 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 1,181 | What the big secret with getting the oil pump to pick up the prime?
I need to see if everythings alright before I close the motor up. I have the correct tool to reach and turn the rod, but after several minutes on several speeds I cannot see any oil flowing through and out of the rocker assem. Does it take awhile for the oil filter to become saturated? | | |
#10561 04/22/2002 1:04 AM | Joined: Oct 2001 Posts: 130 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2001 Posts: 130 | hello modelman. which engine are you working on? i ask because some engines have a different procedure to get the oil from the pump to the top of the engine. for example , some v8 engines have to have the distributor housings or a blank housing to complete what would otherwise be an open passage.
our garage is a non-profit organization
#10562 04/22/2002 3:48 AM | Joined: May 2001 Posts: 41 Member | | Member Joined: May 2001 Posts: 41 | If you changed the oil filter and didn't fill it before you installed the new one it will take quiet awhile to get oil to pump anywhere else first. It will try to fill the filter up.
37 Chevy 1/2 Ton 86 Chevy Blazer 98 Drudge 24 valve Cummins One worn out Timberjack
#10563 04/22/2002 5:15 AM | Joined: Mar 2001 Posts: 1,181 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 1,181 | GaryG,
I have a 305 V-6, I pulled the filter cartridge and it was well saturated and full. If I am not mistaken the firing order on my truck will have the distributor running counter clockwise.
I removed the oil cart. holder and put a LARGE pan under the holder and spun the pump shaft with a drill and the oil flowed out like a faucet, no problem with the pump. Closed everything up and pumped for 3-4 minutes still nothing can be seen "lubricating the rocker arms assemb." I though I would at least see a drip or two!
Next thing I will try to do and it will cost me a gasket it to remove the cam shaft and lifter cover to see if there is any oil going in there.
There has to be a reason for this. Do you think that I have to trun the crank a few revolutions to check that. It turns great, I don't know what to check next.
Any ideas would be great. | | |
#10564 04/22/2002 7:55 AM | Joined: Aug 2000 Posts: 523 Member | | Member Joined: Aug 2000 Posts: 523 | Model....One thing for sure...don't start the motor til you know you have oil flow
I've seen what happens when people say oh hell I'll start it!!
Off to Italy in the morning!! | | |
#10565 04/22/2002 11:17 AM | Joined: Jan 2001 Posts: 662 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 662 | Yes, turn the crank. Turn it 90 degrees or so and prime it. Continue for at least one revolution. I'm not familar with your V6, but usually some of the oil passages see pressure only at certain points of the rotation. | | |
#10566 04/22/2002 3:09 PM | Joined: Jul 2000 Posts: 962 Shop Shark | | Shop Shark Joined: Jul 2000 Posts: 962 | Yup, don't fire it till you see oil at the right places. I don't know the oil flow pattern in a 305-V6. On some motors, lack of oil to the rocker assm can mean a misaligned bearing shell or a loose/missing oil galley plug somewhere.
good luck
chip
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
#10567 04/22/2002 10:03 PM | Joined: Oct 2001 Posts: 130 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2001 Posts: 130 | hello modelman.i went way back in the lounge section to look at the pictures of your engine and see what kind of rocker arms it has. i would loosen up those rocker shaft supports and lift them up a little to see if there is oil supply holes in them to feed the shafts. some times oil is delivered through the supports to the shafts, sometimes the supports that supply oil have special skinny bolts to allow oil to flow.try turning the oil pump with these supports lifted a little. you'll have to readjust the valves later , but i think it's worth a look. maybe a bolt is in the wrong place,or the supports are a little clogged. you mentioned media blasting some parts, is it possible a little media got trapped inside? just a few more ideas. hope this helps. good luck.
#10568 04/22/2002 10:44 PM | Joined: Oct 2001 Posts: 194 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2001 Posts: 194 | On my 228 GMC I had to run the drill a long time before I started to see oil running of the rocker arms. It was like 5 minutes or so. I also agree, don't start it until you are sure everything is getting oil. | | |
#10569 04/23/2002 1:49 AM | Joined: Mar 2001 Posts: 1,181 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 1,181 | I'll pull the rockers arms later this evening and then run a micro brush through all ot the openings. According to the Shop Manual, the oil does push up to the RA shaft and then flows toward the rear off the motor then downward to the pan., Push come to trample, i'll pull the cam shaft cover and check that area.
Jake | | |
#10570 04/23/2002 3:56 AM | Joined: Dec 2000 Posts: 64 Member | | Member Joined: Dec 2000 Posts: 64 | As you are turning the oil pump look down in the hole where the distrebutor should be and see if the oil is flowing into this hole and returning to the pan. If it is, then it is the same as a 350 chev. On the 350 you have to either, use an old distributor with the gear removed and turn the oil pump with it, or machine a piece of pipe with a groove cut around for the oil to flow by. It is by far easier to find an old distributor and remove the gear. You have to do this to get the rocker arms to oil.
kdot em3
#10571 04/23/2002 4:13 AM | Joined: Mar 2001 Posts: 1,181 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 1,181 | | | |
#10572 04/23/2002 9:59 PM | Joined: Oct 2001 Posts: 130 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2001 Posts: 130 | modelman, that is great news! good luck with the project.
