6 members (51sub, JW51, 55shaker, Stovebolt48, Gray_Ghost, 1 invisible), 71 guests, and 0 robots.
Topics128,042
Posts1,055,595
#1055528 09/11/2014 11:40 PM
Found a door on a 58 good cond. BUT truck was on fire(complete truck) Would the heat from the fire harm the metal? what are your thoughts,any one??
Midpiner #1055533 09/11/2014 11:56 PM
I think the worst that will happen, the sheet metal will be warped from the heat, & will be too difficult to straighten.
How straight is it?
Is the paint burnt off & rusted yet?
Midpiner #1055539 09/12/2014 12:19 AM
Door is straight,all paint is burned off and rust is all over outside (inside to i am sure.
Midpiner #1055560 09/12/2014 1:11 AM
I would prefer a burned up, straight, rusty door over a rusty dented up one. You have to media blast most of them anyway.
Carl
Midpiner #1055903 09/13/2014 4:35 PM
Look at this thread and pay close attention to post number 8. James has brought a few burned vehicles back from the grave that had been written off otherwise...
http://www.allmetalshaping.com/showthread.php?t=8460
Midpiner #1055978 09/13/2014 11:03 PM
Thanks for your insights.Cab is out being media blasted now so door could go next.
Midpiner #1056364 09/15/2014 5:47 PM
With the heat of fires, a lot of time the metal gets so warped in many directions that you're better off to throw the piece away and get another one. It can also lose its temper and be brittle and hard to work with. It's possible to use a burnt panel, but I never would if I had the option.
My 46 GMC on Photobucket
