4 members (Wally / Montana, Lightholder's Dad, 2-Ton, 1 invisible), 109 guests, and 1 robot.
Topics128,051
Posts1,055,730
#1053992 09/04/2014 11:53 AM
Discovered on a fluke that my vaccum hose from the manifold to the cab Tee was bad.The hose is super stiff and wire renforced.Would a current stiff nylon hose serve the purpose? Does the old style hose still exist?
1959 Chevy Viking 60 & Wrecker
See I told you it would work. That Beaver Cleaver will do anything.....
Regular vacuum hose will be just fine. Usually the reinforced hose is rated for gas/oil applications.
changed the hose seems to idle better but i did note that when i change the 2 speed rear from high to low in low the motor stalls. not hearing a vaccum leak but i ponder if another hose on the low side of the switch is bad as well?
Does it only happen when going from high to low and not from low to high?
Does the engine run fine once it is restarted or does it stall or idle poorly as long as it is in low?
My 1954/55 GMC 2-ton GMC has a variety of flexible/rubber hoses in the vacuum systems (hydrovac brakes, rear-end selector, speedometer gear selector, PCV, and wiper motors - no vacuum advance on the distributor).
I found a great local hydraulic hose company that fabricated new hoses for about @$20, using the old brass/metal ends and brazing-on new-style brass hose-connectors. If you get desperate for a hose, you might contact them. The added cost of shipping would not make these repaired hoses more expensive than a replacement hose with fittings, if you could find one.
http://www.omniservices.com/ (my location: Omni Services, 190 Old Loudon Road, Latham, NY 12110, Phone: 866-396-4656) - 1-2 day turn-around for my jobs.
This is my first time dealing with this type of plumbing. I have just about finished restoring/renovating all the plumbing. This included cleaning all tubes, joints/ends, junction blocks, adapters, and one-way vacuum-stop valves (or, whatever they are called).
At each inverted flare, a rubber-ring was used between the flare-end of the tube and the tube nut (on GMCs - I do not know about Chevy big trucks). I am using o-rings.
I hope I have no vacuum leaks. The GMC Maintenance Manual describes a Vacuum Leak Test. I hope I do not have to give up and simply/only drive in low-range.
Please let us know what you go through to resolve your problem. Thanks.
Jim....the motor runs ok when in high range but when u shift to low stalls out at idle otherwise shes a champ
