5 members (treegrower, Bill Hanlon, Hotrod Lincoln, HandyAndy, FAST55), 186 guests, and 7 robots.
Topics128,077
Posts1,056,015
Members48,433
#1055472 09/11/2014 7:43 PM
rwb
Offline
engine rebuilt and is timed properly. all new plugs and wires.
points new and proper gap.vac advance working.
carb rebuilt clean fuel. vac advance working.
now it has a dead spot when increasing from idle
to about 700 rpm (will die) go past and is fine.
other than that engine runs pretty good.
put vac gauge on and adjusted carb screw.
is this possible a distributor advance prob ??
i have a 1961 engine i could take dist off to see ??
or could carb be causing it ??
rwb #1055477 09/11/2014 7:51 PM
H Online: Content
Check to see if a wire inside the distributor is shorting out as the vacuum advance moves. That was a common problem on the mid-1950's Fords, but they had a flexible wire between the distributor housing and the points that would develop broken strands. The wire from the coil to the distributor on yours might have a similar problem.
rwb
Offline
wires look good.
there is some slop/movement on dist
vac advance arm while engine not running
should there be any ??
the 61 engine has a little slop also but runs fine.
will the 61 dist work on a 59 so i could swap ??
thanks
rwb #1055507 09/11/2014 10:22 PM
How much vacuum did the gauge show at idle and was the needle steady? Have you readjusted the valves since the engine was rebuilt? Float level maybe a little low?
rwb #1055549 09/12/2014 12:51 AM
I would suspect accelerator pump. It provides a little extra fuel when you step on the gas. Since you say it runs fine once you get past the dead spot, it would suggest that the ignition is working properly (unless someone slipped some Ford distributor guts in on you. Just pulling your good leg, Jerry smile ). You can check the accelerator pump by looking down the throat of the carb while you goose the throttle, engine off. You should see some gas squirting.
Carl
rwb #1328967 10/06/2019 3:44 AM
Just to be complete here, are you positive you have a good vacuum advance? If the diaphragm is split or broken, that will leave you with a vacuum leak.
Mike
