1 members (baldeagle),
91
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2001 Posts: 78 Member | | Member Joined: Sep 2001 Posts: 78 | Has any one used rust-solve at cleanrust.com. I've never heard of it has anyone tried it. Thanks | | | | | Joined: Jul 2001 Posts: 149 Member | | Member Joined: Jul 2001 Posts: 149 | Very interesting! I may order a gallon just to try it out! Will update if I do. I have tried everything else. Might as well add it to my list! Kinda courious what the active ingreident is I didnt see whay they claim it works. Later :confused:
"Finish the thing, do it right the first time, and drive the S.O.B.!"
1949 Chevy half ton 3100 In a kazillion pieces 2000 GMC Serria 1500 SL 4x4
| | | | | Joined: Jan 2001 Posts: 45 Member | | Member Joined: Jan 2001 Posts: 45 | I see KROIL penetrating oil makes a rust remover you mix with water. Has anyone tried that one ? I ordered a sample trial size for 7.95 and no shipping charges to try it out. Mike | | | | | Joined: Jul 2001 Posts: 149 Member | | Member Joined: Jul 2001 Posts: 149 | Well I called the number and talked the guy at the company, he sounded Australian or something. He said you have to keep the bloody thing wet with solution for 3-5 hrs. Spray down the whole lot, as he says, and catch the runoff to be resprayed and keep spraying it every few mins too keep it wet. We were speaking of how to use it on fenders and such. After it dose its job it just washes away. Guess I could get about ten gals and put a fender in the bath tub and keep pouring on to it. (yes I live alone-I wonder why sometimes) Iam going to try a gal of it and see. Will update. Later
| | | | | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Mallard - Try soaking a towel with it, and wrapping the whole thing with saran wrap to seal in the moisture. I've used this with other products.
Fred 52 3600 69 C-10
| | | | | Joined: Jul 2001 Posts: 149 Member | | Member Joined: Jul 2001 Posts: 149 | Fred T Good idea! Was thinking for fenders and hood could buy a Kiddie pool and put it in there then soak a old sheet or something and cover it! Later
| | | | | Joined: Aug 2000 Posts: 122 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 122 | I just ordered a gallon of it. Can't hurt to give it a try. I will give it a try on some especially rusty parts I have lying around. I will post an update next week once I have a chance to try it out.
Steve 55 1st Series 3/4 ton
