4 members (1955 1 Series, baldeagle, Shaffer's1950, 1 invisible), 95 guests, and 1 robot.
Topics128,015
Posts1,055,335
Members48,419
#105530 01/11/2002 1:01 AM
Has any one used rust-solve at cleanrust.com.
I've never heard of it has anyone tried it.
#105531 01/11/2002 11:36 PM
Very interesting! I may order a gallon just to try it out! Will update if I do. I have tried everything else. Might as well add it to my list! Kinda courious what the active ingreident is I didnt see whay they claim it works. Later :confused:
"Finish the thing, do it right the first time, and drive the S.O.B.!"
1949 Chevy half ton 3100 In a kazillion pieces
2000 GMC Serria 1500 SL 4x4
#105532 01/11/2002 11:50 PM
I see KROIL penetrating oil makes a rust
remover you mix with water. Has anyone tried that one ? I ordered a sample trial size for 7.95 and no shipping charges to try it out.
Mike
#105533 01/14/2002 7:44 PM
Well I called the number and talked the guy at the company, he sounded Australian or something. He said you have to keep the bloody thing wet with solution for 3-5 hrs. Spray down the whole lot, as he says, and catch the runoff to be resprayed and keep spraying it every few mins too keep it wet. We were speaking of how to use it on fenders and such. After it dose its job it just washes away. Guess I could get about ten gals and put a fender in the bath tub and keep pouring on to it. (yes I live alone-I wonder why sometimes) Iam going to try a gal of it and see. Will update. Later cool
#105534 01/15/2002 3:35 AM
Mallard - Try soaking a towel with it, and wrapping the whole thing with saran wrap to seal in the moisture. I've used this with other products.
Fred
52 3600
69 C-10
#105535 01/15/2002 5:46 PM
Fred T Good idea! Was thinking for fenders and hood could buy a Kiddie pool and put it in there then soak a old sheet or something and cover it! Later
#105536 01/15/2002 6:03 PM
I just ordered a gallon of it. Can't hurt to give it a try. I will give it a try on some especially rusty parts I have lying around. I will post an update next week once I have a chance to try it out.
Steve
55 1st Series 3/4 ton
