| | | Forums66 Topics128,095 Posts1,056,078 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | I have a distributor part #1112414, I can find one reference to it in all the ether. But I can't find the original application, I do know it is an oddball. | | | | | Joined: Jul 2010 Posts: 59 'Bolter | | 'Bolter Joined: Jul 2010 Posts: 59 | I'm finding a lot of GMC references. Here is an ebay auction for an NOS one (ended). http://www.ebay.co.uk/itm/56-57-58-59-GMC-6-Cylinder-Ignition-Distributor-NOS-GM-Delco-Remy-1112414-/261253833833?nma=true&si=6MAHKO1s1MdoswclsglmMCVD07M%253D&orig_cvip=true&rt=nc&_trksid=p2047675.l2557
1955.1 GMC Suburban Hydramatic
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | Yeah, I saw the Ebay thing, but those are notorious for being wrong. However that along with the other post is making me understand why it isn't matching up with the 216 distributor shaft inside it. Wonder if that is why the coil contact on the inside of the cap disintegrated after about a thousand miles? I do have the invoice, but they didn't really want much to do with it, as I have had it for about 4 years. But in light of this, they will probably reconsider. | | |
