| | | Forums66 Topics128,163 Posts1,057,044 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2007 Posts: 137 'Bolter | | 'Bolter Joined: Jun 2007 Posts: 137 | My ring gear is wore out on the used side. I have not located where to buy a replacement for this model. Is it possible to remove the ring and turn it over for more use? Thanks | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | VCCA member,Al Suehring has them for sale. His number is 715 677 3809. | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | I have seen them turned around so the other side can be used. It takes patience to get them off and on again without damage. Usually heating them will make them come off pretty easy and then heat again to slide it back on. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Don, Don,t you have to grind the new inside edge to make it fit? | | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | I must be getting dense anymore. I'm looking at this and thinking how can you turn over the ring gear (differential)..... Then it dawns on me you'nes are talking about the starter ring gear on the flywheel...LOL
John | | | | | Joined: Mar 2012 Posts: 211 'Bolter | | 'Bolter Joined: Mar 2012 Posts: 211 | Don't feel bad, I was thinking the same. I must be getting dense anymore. I'm looking at this and thinking how can you turn over the ring gear (differential)..... Then it dawns on me you'nes are talking about the starter ring gear on the flywheel...LOL
John | | | | | Joined: Jun 2007 Posts: 137 'Bolter | | 'Bolter Joined: Jun 2007 Posts: 137 | Thank you for all the help. | | |
