4 members (74cheyennesuper, Ponchogl, baldeagle, NJC), 73 guests, and 5 robots.
Topics128,014
Posts1,055,328
Members48,419
#105489 07/17/2003 4:01 AM
Junior Member
Junior Member
I just got done trying out my old sand blaster grin on my running boards, now can I still use an etch primer, or should I get epoxy primer? I had planned to use Martin/senour paints (NAPA) to try and cut costs, and have etch primed the cab already, but feel I should be using epoxy primer instead. frown I am not sure if I should etch prime on sand blasted parts, or best way to surface prep before primer. Can anyone help? :confused: :confused: I haven't opened the paint yet, I can take it back.
"Boop-Boop-a-doop"
#105490 07/17/2003 9:01 AM
etch than epoxy
DUSTY G.
you can do anything you want as long as you have an O [censored] man in case you mess up
