1 members (dunfire), 157 guests, and 2 robots.
Topics128,162
Posts1,056,941
Members48,458
#105447 03/02/2005 6:45 PM
A lot of talk about using POR15, but only a few comments about shelf life. I ran into this conversation on another forum and thought some of you guys may find it interesting. I copy/paste most of the thread and put the pertinent comments in BOLD text.
Quote
Por 15 will dry to a glossy black finish, however if exposed to sunlight it will change color. It sticks tenaciously to rusted metal. If you are applying it to bare clean metal then a metal etching solution that por 15 sells must be applied or it will not stick.
It will not stick to galvanized metal without the cleaner and etching solution applied prior to the por15 being applied. Also once you open the can it will begin to set. it does not have a solvent in it as a paint does. The por15 sets when it contacts the moisture in the air. If you plan on resealing the can to save unused material then you must place several layers of plastic kitchen wrap between the lid and can or you will nver seperate the two again, sort of like" till death do us part".
Iwould recommend getting multiples of their small cans , less waste that way.
Tom M
Reply To This Message
Re: POR 15
Author: george (---.ma.dl.cox.net)
Date: 03-02-05 06:30
I have had good luck sealing POR cans by not installing the lid, rather use the foil type aluminum duct tape. four strips or so 4" long will seal the top. The adhesive is VERY sticky . press tightly allaround the lip surfaces. POR 15 also sticks tenaciously to hands and anything else. Use rubber gloves.
They say ultra violet light only dulls the paint if exposed to direct sunlight, not the underside of cars. Even if dulled, it is not suposed to hurt the rust protection.
Re: POR 15
Author: Chris (---.ext.ti.com)
Date: 03-02-05 08:36
I used the silver POR15 because it is suposed to have small particles to fill pinholes. I replaced the fornt and rear floors of my '64 Monza 'vert with new floors form one of the vendors. The new floors do not replace the metal under the drivers and passenger seat, so I used the Sliver POR 15 to fill thre pin holes I had there. I am very pleased with the results the POR15 dries hard as an anvil. A few words of caution, DO NOT spray POR15, instead apply with a brush, wear a respirator, gloves and gogles.
Now, tricks for preserving POR15 in the can, DO NOT open the can, instead use 2 self tapping sheet metal screws with the steel washer and rubber gasket on them, the type used to put corrugated tin on a barn. Insert the screws 180 degerees apart in the BOTTOM of the can. Remove both screws to pour out only what amount you can apply in 15 minutes or less. replace the screws and place can aside RIGHTSIDE up, POR15 stored this way is good for at least 2yrs in my experience.
Chris
NTCA
CORSA
'64 Monza 'vert
Re: POR 15 one other piece of advice
Date: 03-02-05 08:41
Oh yeah, I forgot to mention try to avoid contact with your skin, this stuff will not come off if you happen to get any on you, you'll be wearing it for at least 2 weeks. DAMHIKT
Couple unusual ideas, but it works for them.
'67 GMC 3/4 292 4spd
#105448 03/04/2005 2:17 PM
I've used it in various forms for over 10yrs. The simple, but a bit messy, solution is to use enough plastic wrap to contact the material in the can which "seals" it from moisture. I once kept a can for nearly a year that way. Was a lil thicker but some reducer brought it around and the same results achieved.
#105450 03/08/2005 6:41 PM
I use the plastic wrap system too, at least a few layers thick and the lid hammered down tight as you can. Got to make sure both lid and channel are clean! Then I stick it in the fridge! Just used some the other day that had been in the fridge for over a year and it was fine!
Just trying to avoid the potholes on the road of life!
49 Chevy COE
55 Chevy pickup
+ way too many other project vehicles!
#105451 03/08/2005 11:18 PM
I punch a hole in the can to pour it out, then seal the hole with duct tape and stick it in the refrigerator. Been there 2 years and still slops around like new.
'53 chevy 3/4 ton
