3 members (gswbbc, Millenimech, jmoore), 90 guests, and 2 robots.
Topics128,031
Posts1,055,434
Members48,422
#1054328 09/06/2014 1:52 AM
My 1951 3100 with the original 216, 76,000 miles, does not have an oil filter.
Two questions;
How important is it to have one, if i change the oil everything 1,000 miles?
If it is recommended, how hard and what would the rough cost be to install one?
Thanks in adavance everyone.
Brad.
Cadee #1054336 09/06/2014 2:19 AM
Ex Hall Monitor
Ex Hall Monitor
You will get a number of opinions on this. My opinion is that any filtration is better than none. It is true that Chevy went decades with no factory filter, relying of frequent oil changes BUT during that time engines typically needed rebuilt after relatively few miles. I'm sure there are others who have differing opinions and I'm sure you'll see them in this thread.
Cadee #1054341 09/06/2014 2:29 AM
if you just use a bypass filter it is really easy, I have a really cool bypass that bolts in place of the oil distributor. If you decide to use a full flow filter, then you need to do some drilling and tapping, I don't think you can do a full flow without pressurizing/drilling the crank. I don't feel like thinking that hard right now.
Cadee #1054344 09/06/2014 2:39 AM
U
U Offline
Anything related to oil causes world-wide problems, but Here's another thread with good information that might help you.
If you read the tech tips linked in the thread by another bolter here , and here, I think you will be able to answer your questions. Like Tiny says, opinions vary from the subjectivity of the subject, but those are two outstanding tech tips either way.
Hope it helps!
(another) Brad
Wrench Fetcher, PhD
