2 members (J Lucas, pauld),
123
Mod | | | Forums66 Topics128,183 Posts1,057,263 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 1,554 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,554 | I was just looking at the hood hold open supports from jim carter and was wondering if anyone has them on their 41-46. Do they work good and are they worth it? Dave 1941 Chevy"First rebuild - complete!"Follow the story in the DITY1941 GMC resting peacefully 1946/1947 Chevy Street rod on s10 frame complete 1945 GMC panel truck in line for restoration 1941 Plymouth stock complete 1941 GMC COE in restoration processRead his Project Journal1941 Chevy Coe uncertain future resting now
| | | | | Joined: Jan 2003 Posts: 354 'Bolter | | 'Bolter Joined: Jan 2003 Posts: 354 | Do you mean the ones originally made for a GMC? I didn't like the looks and feared they would add another rattle (not that another one would be noticed) so I made my own out of a piece of scrap steel rod, scrap sheet metal bracket, couple bolts, and faucet washer for a bumper. A few poor quality photos here: http://s1253.photobucket.com/user/harold4152/library/Hood%20Prop
Harold Wilson 41 Chevy 3/4 Ton
| | | | | Joined: Nov 2005 Posts: 1,554 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,554 | 1941 Chevy"First rebuild - complete!"Follow the story in the DITY1941 GMC resting peacefully 1946/1947 Chevy Street rod on s10 frame complete 1945 GMC panel truck in line for restoration 1941 Plymouth stock complete 1941 GMC COE in restoration processRead his Project Journal1941 Chevy Coe uncertain future resting now
| | | | | Joined: Jan 2011 Posts: 212 Shop Shark | | Shop Shark Joined: Jan 2011 Posts: 212 | I made my own also..I just formed a flanged closed "C" using some fairly thin Steel and had a swivel Bolt through the Flange to hold the Arm, which Arm would hold the Hood up.
Flanged "C" of course mounted on the grille support Rods.
Arms were 1/4 x 5/8ths White Oak with padded ends...Arms also had a small thin strap Steel Hook toward their top, to hook over the Grille support Rod, when at rest.
I did those in 1977 and they worked perfectly and held up fine for the next 23 years of daily use. | | | | | Joined: Nov 2005 Posts: 1,554 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,554 | I wish you had a picture, but I guess that is not possible. 1941 Chevy"First rebuild - complete!"Follow the story in the DITY1941 GMC resting peacefully 1946/1947 Chevy Street rod on s10 frame complete 1945 GMC panel truck in line for restoration 1941 Plymouth stock complete 1941 GMC COE in restoration processRead his Project Journal1941 Chevy Coe uncertain future resting now
| | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | I got the ones from JC. They don't rattle at all, and they stay put even when I drive the truck without the hood, at any speed.
They only really allow you to have your hood partly open (I use it to support the hinge between the hood side and hood top), but they work great. Being that mine is a GMC and my support rod is bigger I had to drill out the holes larger, but other than that they're worth every penny. | | | | | Joined: Nov 2005 Posts: 1,554 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,554 | 1941 Chevy"First rebuild - complete!"Follow the story in the DITY1941 GMC resting peacefully 1946/1947 Chevy Street rod on s10 frame complete 1945 GMC panel truck in line for restoration 1941 Plymouth stock complete 1941 GMC COE in restoration processRead his Project Journal1941 Chevy Coe uncertain future resting now
