0 members (),
244
Mod | | | Forums66 Topics128,101 Posts1,056,181 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2012 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2012 Posts: 46 | All of my life in this hobby, I have taken my sheet metal down to bare metal,then epoxy primed it. Did my body work on top of the apoxy and then used Evercoats Featherfill or Slick Sand to get it straight and then recoated it with epoxy prime before color. Am I living in the past? or is there a new way to achieve the same affect? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | about usual, although you shouldn't need the 2nd shot of epoxy primer, a sanding primer or sealer primer before the color is "standard"
Bill | | | | | Joined: Mar 2012 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2012 Posts: 46 | red58, I guess I could eleminate the last apoxy coat and see how that works and if I have a sand through, just cover it with a coat of slick sand. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | maybe you need to be starting with straighter metal - the object of the first epoxy coat is to seal the metal, you don't want any breaks in that, the object of the sanding/high fill primer is so there's something to sand to avoid going into the epoxy, which isn't really intended for sanding except any necessary scuff after the recoat limit ... just my 2¢
Bill | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | How are you living in the past using all the modern products ? 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Shouldn't guide coating, and fixing accordingly, result in very little final sanding? It is to prevent just random sanding.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | |
