0 members (), 40 guests, and 2 robots.
Topics128,030
Posts1,055,428
Members48,422
#1053576 09/02/2014 7:22 PM
Doing the final stuff to prepare for my first fire-up on my `59 Chevy 1/2 ton. Far from driving, but excited to hear run after 2 years of work. I've got a 3 speed manual transmission with OD out of a `55 210 Chevy. Currently figuring out and installing the extra wiring harness for the trans. Could anyone supply a pic or two of the mounting location of the relay and the kickdown switch? Also reading down through the shop manual it details how to fill the trans with lube, but I don't see where it says what to fill it with.
1959 Shortbed stepside 1/2 ton project
[Linked Image from i236.photobucket.com]
olddaze #1053599 09/02/2014 9:24 PM
I don't know how the original relay and switch were mounted on a truck but here is a link to wiring diagrams, operators manual, service manual and other documents.
olddaze #1053600 09/02/2014 10:03 PM
the relay was mounted on the firewall near the regulator, the kickdown switch was on a bracket on the carb, like the one for an automatic trans, so it gets activated by the throttle linkage
olddaze #1053802 09/03/2014 4:26 PM
Use GO 90 in both the OD and the trans.
Fred
