Fixing the old truck
BUSY BOLTERS
Are you one?
Where is it?? The Shop Area
4 members (GMCJammer51, Rnl364, Gooberdog, Peggy M), 531 guests, and 1 robot.
Topics126,777
Posts1,039,270
Members48,100
Most Online2,175
Jul 21st, 2025
Just wondering if the driveshaft (enclosed) and the rear diff share the sMe oil? Also what is a good recommended wt? I have some valvoline synthetic 75 90 and also some 70 140
What year truck? The recommended weight should be listed in the Shop Manual and/or the Operator's/Owner's Manual.
The driveshaft (enclosed) and the rear diff not share back-and-forth the same gear oil, but you usually use the same gear oil in both components.
In an enclosed drive-shaft truck, the transmission oil is "shared" back-and-forth with the gear oil around the enclosed u-joint. However, there is a seal at the u-joint end of the enclosed drive-shaft (torque tube). The torque-tube shares gear oil with the rear end.
Either weight gear oil should be OK. I usually use a 90 wt gear oil in my 1954 trucks rear ends and in SM42 4-speed transmissions (all years).
I use 80-90 Vavoline gear oil in my beast with has a similar drive train.
Craig
ODSS Lawman
ODSS Lawman
Don't forget to add a pint of the same gear oil where the u-joint is located!
SWEET
1950 GMC 450
1951 Chevy 1/2-Ton
The GreenMachine
If the truck has a Hydra-Matic transmission, NO
If the truck has a manual transmission, NO
There is a oil seal at the tranny end of the (enclosed) driveshaft that keeps the tranny gear lube out of the rear axle.
You could say, the tranny gear lube, lubes one end of the (enclosed) driveshaft and the rear axle gear lube, lubes the other end of the (enclosed) driveshaft. Illustration (scroll down) Truck & Passenger car virtually use same(enclosed) driveshaft.
If the truck has manual tranny, the gear lube weight is the same that is in the rear axle.
They just don't share it.
90 weight is what is normally used. check manual
(Release build 20240826)
Responsive Width:
PHP: 8.3.11 Page Time: 1.246s Queries: 14 (0.042s) Memory: 0.6183 MB (Peak: 0.6801 MB) Data Comp: Zlib Server Time: 2025-09-22 12:35:59 UTC
Valid HTML 5 and Valid CSS
