| | | Forums66 Topics128,028 Posts1,055,414 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2011 Posts: 110 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2011 Posts: 110 | Doing the final stuff to prepare for my first fire-up on my `59 Chevy 1/2 ton. Far from driving, but excited to hear run after 2 years of work. I've got a 3 speed manual transmission with OD out of a `55 210 Chevy. Currently figuring out and installing the extra wiring harness for the trans. Could anyone supply a pic or two of the mounting location of the relay and the kickdown switch? Also reading down through the shop manual it details how to fill the trans with lube, but I don't see where it says what to fill it with.
1959 Shortbed stepside 1/2 ton project ![[Linked Image from i236.photobucket.com]](http://i236.photobucket.com/albums/ff117/olddaze/Chevy%20truck%20project/photobucket-4342-1325944221019.jpg) | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I don't know how the original relay and switch were mounted on a truck but here is a link to wiring diagrams, operators manual, service manual and other documents. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the relay was mounted on the firewall near the regulator, the kickdown switch was on a bracket on the carb, like the one for an automatic trans, so it gets activated by the throttle linkage
Bill | | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | Use GO 90 in both the OD and the trans. Fred
