3 members (TexasJim50, 1955 1 Series, Rexville48), 103 guests, and 3 robots.
Topics128,141
Posts1,056,488
Members48,441
#105348 03/12/2003 2:09 PM
hello everyone well the weather here is gettin alittle better here and that means I can finally start sand blasting,but before I do that I want to remove the grille(which is chrome painted over)and take to local shop to be rechromed my ? is can someone give me some insight to removing the dang thing the proper way instead of just goin in with the sawzall ireally want to use chrome if I can instead of the painted over mess i have now,also my b-i-l got a goooood deal on his **** parts he had done, thanks
From memory - a dozen or so screws into the bottom through the lower radiator baffle. 3 screws into each side from inside the fenderwell. The upper rad baffle has to come off (another dozen or so screws) to get to 2 screws on each side from the fender into top bar. PITA to get to these - a small air ratchet is handy.
