8 members (msmall, 68ironhead, Shardean, DannyW, Eisenholtz, 3800GUY, Shade Baby, cmayna), 41 guests, and 1 robot.
Topics128,023
Posts1,055,367
Members48,420
#105342 12/15/2001 11:00 PM
I am about to fill prime my truck, What grit sandpaper should i sand the truck with before applying the Urethane primer? The truck is currently in primer, also what is a good product to wipe it down with before application?
1972 Chevy Cheyyenne, 1959 Chevy Apache
#105343 12/16/2001 6:42 AM
Pappa, 180 would be fine on the sand paper. It will give a good bite and urethane would fill 180 in one coat, though I suspect you will be applying more. As for wiping it down, get some mild "wax and grease remover". Wipe it on wet on a small area (half a fender or so at a time) then wipe it OFF with a clean rag while it is still wet and holding the contaminants off the surface.
1948 Chevy Pickup
Chopped and sectioned
owned since 1974 when I was 15.
