5 members (51sub, walter74, Gdads51, MickeyP, Chip O), 67 guests, and 2 robots.
Topics128,041
Posts1,055,593
#1052748 08/29/2014 11:56 PM
About ready to paint a new front bumper for my 58. Can someone tell me if the bumper bolts were painted on these when new or were the bolts stainless?
Thanks for your help.
I believe the bolts were painted. Many use stainless and leave unpainted, including me. I wanted the truck restoration done done done, so I skipped the painting of the bolts step. Looks ok,and most would not know the difference.
painted bumpers got painted bolts, chrome bumpers got SS capped bolts
Thanks for the answer.
I dont think Ive ever seen a painted bumper with painted bolts from the factory
I do know that the 60's thru 80's trucks with a painted bumper came from the factory with chrome bolts.
Unless 50's on back were different?
What I have been noticing on pristine pre-60s trucks is that most fasteners were not painted. Some exceptions are sub-assemblies pre-assembled prior to paint.
On pristine "pre-60s" Task Force (and, maybe Blue Chip) trucks.
I am glad this was asked and answered. I am using common locally purchased carriage bolts on my painted bumpers. Now that I know they should be painted, I'll not worry about rust runs appearing at some point. I can just clean and paint them.
Drew
What is Blue Chip?
Blue Chip is the name for GMC trucks during Chevrolet Task Force years.
My comment was in regards to which pre-1960 trucks had painted bumper bolts. Chevrolet Advance-Design (and GMC New Design) 47-55 trucks are also pre-60 and they did not have painted bumper bolts.
Tim, You got me. Duh. Thought you meant '47-'55 AD had painted
bumper bolts. It's a daily driver. Might paint them anyway.
Drew
Does this also apply to trucks with painted bumpers? That is, did the '53 models (with grey bumpers) still use the stainless-clad bumper bolts?
1953 Chevrolet 3104 1/2-Ton
More pix
I do not know for certain, but I assume that 1952-55st painted bumpers used bright (stainless-clad) unpainted bumper bolts.
The Master Parts book shows only one type of bumper bolt for those years. We can speculate that the assembly plant would not have had a bin of bright bumper bolts and a bin of anvil gray painted bumper bolts (or, white, on 1955-1st painted bumpers)?
Since I too have a 53 and this question has been one on my list for my restoration too. I am 75% sure the bolt heads were natural, it would of taken an extra step in the manufacturing process to paint them. I'm thinking the assembly line back then was into getting those trucks put together as cheaply as possible. Only other thing that could make me change my thoughts on this is if the bumper and brackets were assembled in advance and then painted in which case the brackets would have gray overspray on them. Were the bumpers and brackets assembled then installed on the vehicle? I'm thinking so. This could be the case. Why we are at it, were the back sides of the bumpers painted too?
1953 Chevrolet 3100
In the DITY Gallery
Video of the 261 running
1964 GMC 1000
