| | | Forums66 Topics128,211 Posts1,057,472 Members48,473 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2014 Posts: 924 Shop Shark | | Shop Shark Joined: Apr 2014 Posts: 924 | For no other reason than to have pictures for reference, here is what the inside of a vacuum advance looks like. This is the diaphragm that is a common cause for the unit's failure to hold 'vacuum.' As these vacuum advance units are available for $30, it's not worth the time to re-build the original ones. I took these pictures last year just to see what all would be involved with replacing the diaphragm, and thought some of y'all might be curious. I couldn’t find my pictures of the dissected spring end of the unit. Brad Wrench Fetcher, PhD | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | I have always planned on cutting one open. Thanks for saving me the time.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Same feeling here Brad. One more thing I can scratch off the list.
That rubberized fabric material that's used in the diaphragms,,, I've been looking for a source for some of that for a long while. Got some ideas for using it else where but can't find any thin enough for a diaphragm. Anyone ever run across any, please let me know about it. dg
Denny G Sandwich, IL
| | | | | Joined: Jul 2008 Posts: 326 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 326 | Denny;
McMaster-Carr has fabric reinforced Buna rubber sheets. The thinnest I saw in their catalog is 1/16". Might be something you can use(?).
SimS | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Yep, lots of that around the net SimS. I deal with McMaster about once a week, they're my mainstay when it comes to hardware. The sheet goods used for diaphragms is a lot thinner, and that's the problem. Buna-N is the correct material for fuel but it has to be very thin, less than a 1/64. Thanks anyway, Denny G
| | | | | Joined: Apr 2014 Posts: 924 Shop Shark | | Shop Shark Joined: Apr 2014 Posts: 924 | I have some small Kevlar sheets that are about 1/128" thick (0.0105" exactly) and my idea was to rubberize or seal it with a fuel-resistant coating, sandwich it together, and see how it worked. Brad's Kevlar-reinforced vacuum advances, or something like that...
Like Denny says, it was difficult to find anything thin enough for the diaphragm material, BUT- if I would have known about this website this time last year, I would have a working rebuilt vacuum advance right now. And that's just from getting the "Buna-N" material validation.
Brad Wrench Fetcher, PhD | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Just how had you planned on sealing up that vacuum chamber after you've cut the crimp off to get it open?????
dg
| | | | | Joined: Feb 2004 Posts: 29,889 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,889 | The oldtime method for checking a vacuum advance unit was to try to blow cigarette smoke through the vacuum nipple. If the smoke came out the other side, we trashed it and installed another one. Occasionally a new one right out of the box would fail the smoke test.
I'd try splitting a piece of 3/16" steel brake line tubing with a cutoff saw in a Dremel tool, wrapping it around the pieces of the advance unit, and sealing it with 5-minute epoxy. Jerry
