8 members (Hotrod Lincoln, 2-Ton, DadsFirstPickup, Otto Skorzeny, HandyAndy, Peggy M, DES57, Jman), 124 guests, and 2 robots.
Topics128,102
Posts1,056,532
Members48,448
#1052356 08/27/2014 11:50 PM
Looking for advice on purchase of wiring harness. Wagon is stock except for 12 volt generator. Does the 49-50 truck harness appropriate or should I look for a 50 passenger harness. Ron Francis Wiring or Classic Truck. Only want the basics for a stock instrument panel. Want connections that directly hook up to stock dash gauges. Thanks for your input
truck and car chassis and dashes are enough different I'd expect problems someplace trying to mix them, get the car harness .... someplace like https://www.chevsofthe40s.com/ or maybe https://www.fillingstation.com/ or even http://www.truckandcarshop.com/ should have stock stuff
Thanks for your advice. Will stay away from truck harness and concentrate on car harness, using your recommendations.
