2 members (Steveoreno, TPR57C),
106
Mod | | | Forums66 Topics128,186 Posts1,057,320 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2014 Posts: 35 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2014 Posts: 35 | Gotta replace both windshield halves and both door windows...
ALL the window rubber and also the metal molding that trims the door windows looks too ruff to bring back.
Any after markerters that do a proper job with such things??
Thx. GiG | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | are you looking for someone to do the job or a place to buy the parts? all the vendors have the seals, and likely you'll have a variety of auto glass shops around that could cut the glass
Bill | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | If you buy the glass from an on-line vendor, buy the seals and setting tapes from that vendor. That way, you are more likely to have things match during installation.
Carefully inspect the glass as soon as you receive it. Look for scratches in the glass and serious chips on the edges. Replace/return if necessary.
| | | | | Joined: Aug 2014 Posts: 35 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2014 Posts: 35 | I own a shop with fellas that are helping me realize my dream truck, so ifin' there's a www place buy what I need - we can do.the install work. | | | | | Joined: Mar 2010 Posts: 10,310 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,310 | I would recommend Steele Rubber Company for the windshield rubber if you want the bottom corners to fit flush on the glass. They are pricey, but so are leaky windshields. Carl
| | | | | Joined: Apr 2004 Posts: 888 'Bolter | | 'Bolter Joined: Apr 2004 Posts: 888 | Ditto on Steele Rubber.....Do you have a glass shop local??? Flat glass is relatively cheap and if it is available locally you save on shipping and handling. Just another option... Have fun and good luck Dan | | |
