5 members (Gray_Ghost, 3B, KEVINSKI, Joe H, Charles in CA), 110 guests, and 0 robots.
Topics128,108
Posts1,056,558
Members48,448
#105135 11/24/2004 2:20 AM
I am planning to buy a new welding machine and maybe a plasma cutter if i can afford both. Any ideas and this and maybe advise on where to buy this equipment? thanks.
Get busy liv'n or get busy die'n
I suggest visiting your local welding supply store. Around here Airgas is the most common. They sell and service welding stuff all day and the prices are usually competetive. They can also give you hints and maybe even let you try stuff out.
If you are not familiar with using the equipment I would take a welding class from your local community college or get friendly with your local high school shop teacher, then you can try out their equipment and see if you like it.
Paint & Body Shop moderator
I am new to welding and went to Airgas, they were very helpful and explained options. I had an idea what I wanted, 110v MIG/Flux home shop use. They want you to be a happy customer.
First figure out all you want it to do and go from there. You can go online to Miller or Lincoln and read through spec sheets.
Buddy
"Keep the shiny side up....."
'50 GMC Suburban
'55 1st Chevy Pickup
http://community.webshots.com/user/buddyinak
