5 members (Bill Hanlon, 68ironhead, 48jim1ton, Hotrod Lincoln, Otto Skorzeny), 121 guests, and 2 robots.
Topics128,032
Posts1,055,517
Members48,425
#1049028 08/13/2014 12:05 AM
kks
Offline
Can someone give me an idea on how to tell if my 54 3100 pickup has been converted to a 12 volt? 6 volt battery is very sluggish and wont turn the truck over. I took the wire off the starter, hooked the battery cable back up to it, dropped a 12 volt in it and it turned right over. Just want to be sure before I put everything back in place. Thanks
kks #1049031 08/13/2014 12:10 AM
Ex Hall Monitor
Ex Hall Monitor
Pop a bulb & see if it's 6 or 12v.
kks #1049082 08/13/2014 2:41 AM
Generator should show the voltage on the tag. John
kks #1049193 08/13/2014 3:28 PM
Unless someone changed the starter, the engine should turn over fine with a 6v battery. If not, then you have a wiring issue from battery to starter and/or ground. Or, the starter is needing attention. Most people don't bother changing out the starter from 6v to 12v as the 6v starter will work and last just fine with 12v. Also, most will convert to alternator when switching to 12v unless an authentic look is high on the priority list. Also, look for voltage markings on the coil.
kks #1049546 08/15/2014 12:19 AM
kks
Offline
Checked all the bulbs in the truck. All are 12 volt. Good indicator? Also the regulator reads 12 volt.
kks #1049557 08/15/2014 1:23 AM
you're 12V, and the generator will be 12V, doesn't really matter about the starter it'll work better on 12V if it is a 6V - carry on, give us the run down in the Welcome or DITY forums, and pics are always of interest
