7 members (TUTS 59, DaveV, Dennys28, Hambone, KEVINSKI, Phak1, Ole49GMC), 84 guests, and 2 robots.
Topics128,195
Posts1,057,376
Members48,469
#104800 05/24/2004 6:40 AM
Junior Member
Junior Member
Hopefully my last request on this round of projects on the truck. I am installing the stock passenger side view mirror. The truck never had one so to my knowledge, I have no reference points. The mirror is the basic round model with the support (arm) that has a slightly different bend than the drivers side. Both have the rounded corner "triangle" base. Any help on the factory location would be appreciated. Thanks!
Check this out:
Side View Mirrors
The BEST way to decide the spot to mount it is to have someone hold it while you sit in the driver seat and direct them. THAT way you KNOW you'll have total view and best use of it!
~~ Alan Horvath
1954 Chevy Pickup
Singing his praises in the
Passing Lane
actually, I did the same thing with my truck. If you look up at the driver's side, and then open up the passenger door and look through the access hole, you should see preformed 3 holes, then you can just drill these out as they exactly match a stock mirror. When I looked at installing the mirror on my truck that's what I found. My door was made with the holes in the door frame, but not on the skin - so you should see the holes for the mirror in the frame. It were easy on my truck.
Junior Member
Junior Member
Arnswine, thanks for the help!!! Sounds right on. Looking forward to installing it in the next few days. When I can figure out how to post photos I will post some. As for the other idea, thanks but I guess I'm kind of anal obout being factory stock. One of those rediculously hopeless restorers.
