1 members (Peggy M),
39
Mod | | | Forums66 Topics128,037 Posts1,055,466 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2013 Posts: 41 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2013 Posts: 41 | I have a 48 3/4ton truck and looking at my front frame I noticed the front crossmember rivets on the driver side are loose. Does anybody know the correct fix for this problem. Should I use bolts or weld or what? | | | | | Joined: Nov 2011 Posts: 1,610 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,610 | Do not weld. If you have the capability to install new rivets, that would be best but you will need lots of access,some special tools plus at least two competent friends. A grade 8 fine thread bolt the same diameter as the hole torqued properly with a lock nut will also do the job. | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | ...link... I used bolts in a different area | | | | | Joined: Jan 2001 Posts: 1,421 ODSS President | | ODSS President Joined: Jan 2001 Posts: 1,421 | I have read or heard here that a rivet on a stovebolt equates to a grade 3, maybe five but definitely not a grade 8.Using a grade 8 is a common practice for any replacements I've had.
Nice clean work as always Dad's 50!
~ Cosmo 1949 Chevy Half Ton Rocinante, like Don Quixote, he is awkward, past his prime, and engaged in a task beyond his capacities. "...my good horse Rocinante, mine eternal and inseparable companion in all my journeys and courses." ...Don Quixote, Cervantes "If you come to a fork in the road, take it."...Yogi Berra "Rudeness is the weak man's imitation of strength." ...Eric Hoffer
| | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | For things like shock towers, the factory should have used grade 8 bolts. Reason they didn't has to do with the really not so perfect 1/8" metal they used for the frame itself. This thin metal can warp, warble and cause a failure so easily. By having ANY space between a bolt and the frame, you can add to this effect. They ruled out this possibility by using rivets. Rivets are the reason they were able to get away with 1/8" frame material. By completely and totally filling the hole so completely it effectively makes the connection as solid as if it were welded (almost), they got away with it. Gus always does an excellent job.. expect nothing else. If I were replacing shock towers, they would get grade 8 bolts. Every shock mount I have ever seen from that era is damaged in some way due to the stresses the factory didn't expect. I weld them up all the time. It wasn't one of the engineers more shining moments. All they should have done was make the shock tower material 5/32 or so. They didn't expect the dang truck to last 100 years! The frame is grade 2 mild steel as well as every part on the frame including the rivets. That really puts you at the mercy of the design. | | | | | Joined: Jan 2011 Posts: 212 Shop Shark | | Shop Shark Joined: Jan 2011 Posts: 212 | If you can borrow the right size Rivet 'Sets' you can Heat the loose Rivet with an Oxy-Acetylene Torch to a nice Cherry 'Red', and, quickly, re-compress the Rivet.
One can also make perfectly good River Sets if need be, using any heavy short-section of Steel Bar Stock, and, modifying a Twist Drill of appropriate diameter to make a round Bottom 'Hole' of the correct depth needed...or by using a 'Burr' in a Drill Press, to Round-Bottom an otherwise shallow conventional Drill profile Hole.
Ideally, new like-same Rivets would be the way to go.
Hot Riveting is fun and satifying, and, pretty easy once one has the hang of it...far better than a Weld, too.
No one ever Welded Frames or other Serious Chassis connections, since Rivets were a superior method, and would never crack from twisting and stressing of the Frame and so on, like a Weld will tend to do.
Substituting a Nut and Bolt with a smooth Shank for the join thickness, is 'okay' also of course, but, never looks right.
| | | | | Joined: Oct 2010 Posts: 202 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 202 | I have had to replace a forward-rear leaf spring mount. I wish I could have attached it with rivets but with my current resources I attached it with, I believe, 5/16 grade, fine threaded bolts. I incrementally torqued it down with my trusty torque wrench to 70 ft/lbs. I hasn't budged in the 14k miles I have driven my 3100.
Walt Williams La Verkin, UT
