8 members (walter74, moparguy, TUTS 59, Wickedbass, 50Chevy3100, FAST55, Wally / Montana, Mike Burns),
91
Mod | | | Forums66 Topics128,065 Posts1,055,870 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2013 Posts: 367 Shop Shark | | Shop Shark Joined: Oct 2013 Posts: 367 | Thanks to those who insisted I do it on my 235. The "pipe" was really full of sludge. After I did it the oil flowed like water. Question: When I took the assembly off the push rods went slack and when I re-assembled and primed the oil pump the rods were not slack. Is this just compression? Here's a pic: http://i.imgur.com/dPlll1W.jpgthese two holes were the distributor mount I am guessing but how do I plug them as they run into the valve chamber? Here's another pic: http://i.imgur.com/Ot0Yg7Yl.jpgIs this oil feed rod (I don't know what it's called) supposed to be crimped like this? | | | | | Joined: Mar 2014 Posts: 161 Shop Shark | | Shop Shark Joined: Mar 2014 Posts: 161 | Holes are for your coil.On my 235 that tube goes into a collar on the center of the rocker shaft.---Jack | | | | | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 | The holes are where the coil mounts, If you have it mounted somewhere else check to make sure the holes don't let oil drip from the head. Use short bolts/screws so as not to jam the push rods for the vavles. The oil feed will be crimped , there are several different ones that where used.
Tommy 59 apache 1/2t 261 short stepside | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | jrdamien, As posted by Tommy, the oil feed tube to the rocker arm was often crimped/cut (by people trying to get more oil into the rocker arm shaft, presumably). Cleaning the assembly should have been the first action, but crimping/sealing the feed-tube was much easier. If you want to be bored with TMI, here is some information, illustrations, and photos of the various styles of "oil connectors" between the rocker arm shafts, 1937-1962. | | | | | Joined: Oct 2013 Posts: 367 Shop Shark | | Shop Shark Joined: Oct 2013 Posts: 367 | So should this tube be opened up? And my coil is mounted to the starer. Any idea what screw size for these coil mount holes. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I would not open the tube, until/unless you know that oil will go through the entire rocker arm.
Coil mounted on what, the starter?
What year and size/model truck? Might you have an electric solenoid starter, and you are referring to the solenoid? Can you post a link to a picture?
| | | | | Joined: Oct 2013 Posts: 367 Shop Shark | | Shop Shark Joined: Oct 2013 Posts: 367 | I would not open the tube, until/unless you know that oil will go through the entire rocker arm.
What year and size/model truck? Might you have an electric solenoid starter, and you are referring to the solenoid? Can you post a link to a picture? The engine is a '60 235. It is a solenoid starter. Here's the pic: http://i.imgur.com/AmHab3Vl.jpgI am just learning about all thing mechanical, from engines on up, so this is all new to me. So what's the different between a coil and a solenoid? | | | | | Joined: Jan 2011 Posts: 212 Shop Shark | | Shop Shark Joined: Jan 2011 Posts: 212 | Yes...the two Holes in the image, are for your Coil to ount - http://i.imgur.com/dPlll1W.jpgI used 4 inch long "Allthread" pieces to mount the Coil in the usual place, on my 1960 235. Lock Nuts to secure the All Thread to the Block...then, the Coil Bracket is about 3 inches out, so the Coil stays 'cool'. Coil Bracket then is secured using Nuts and Washers on each side of the Braket flanges.
| | | | | Joined: Jan 2011 Posts: 212 Shop Shark | | Shop Shark Joined: Jan 2011 Posts: 212 | >>>snip<<<
these two holes were the distributor mount I am guessing but how do I plug them as they run into the valve chamber? The two Holes are for your Coil Bracket to mount. They have nothing to do with the Distributor. The top crimp is correct, do not mess with it. The Tube feeds the Rocker Shafts from where it is brazed to the Shell there, and it feeds Oil to the Shafts from it's side, not it's ( crimped ) end.
