7 members (Gdads51, joe apple, 78buckshot, Hanks custodian, Otto Skorzeny, 1955 1 Series, Rexville48), 122 guests, and 2 robots.
Topics128,070
Posts1,055,896
Members48,428
#1047746 08/07/2014 9:56 PM
Truck had 4 separate keys for 4 locks so I'm replacing all the locks to one key. How do you remove the ignition lock from the ignition? I see the two small holes and I've tried putting paper clips in them but no luck so far.
1955 GMC 100 Series 2
you need to have the key in the switch ['off' position] when you push the wire in the [one correct] hole, it allows the key to turn past on [clockwise] - I believe the procedure is in all the shop manuals
for mine... I put the key in, turned to the 'on' position, pushed the paperclip in, turned it a little more passed the 'on' position, then turned it towards the 'off' position and it popped out
mine only had one small hole though... so I can't tell you which one to use
Ok. I got it. For mine I turned it left (acc?) and then pushed down and it popped out. I read the manual (thanks Bill) but could find anything about re-keying. Thanks for the responses though! Finally, only one key...
manual doesn't say about rekeying, just about replacing the cylinder [engine electrical section I think], a locksmith can change tumblers to change keys
