| | | Forums66 Topics128,068 Posts1,055,880 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2011 Posts: 154 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 154 | Truck had 4 separate keys for 4 locks so I'm replacing all the locks to one key. How do you remove the ignition lock from the ignition? I see the two small holes and I've tried putting paper clips in them but no luck so far.
1955 GMC 100 Series 2
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | you need to have the key in the switch ['off' position] when you push the wire in the [one correct] hole, it allows the key to turn past on [clockwise] - I believe the procedure is in all the shop manuals
Bill | | | | | Joined: Jul 2013 Posts: 388 'Bolter | | 'Bolter Joined: Jul 2013 Posts: 388 | for mine... I put the key in, turned to the 'on' position, pushed the paperclip in, turned it a little more passed the 'on' position, then turned it towards the 'off' position and it popped out
mine only had one small hole though... so I can't tell you which one to use
| | | | | Joined: Aug 2011 Posts: 154 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 154 | Ok. I got it. For mine I turned it left (acc?) and then pushed down and it popped out. I read the manual (thanks Bill) but could find anything about re-keying. Thanks for the responses though! Finally, only one key...
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | manual doesn't say about rekeying, just about replacing the cylinder [engine electrical section I think], a locksmith can change tumblers to change keys
Bill | | |
