4 members (EchoBravoSierra, carbking, 2 invisible), 77 guests, and 2 robots.
Topics128,206
Posts1,057,438
Members48,471
I got this carb. YF 2101 S. I know where the gas goes in, and the vacuum port for the dist. But there is another connection that I don't know what to hook up to it? Or block it off? It seems to be automatic choke. I have been using a YF carb with manual choke. I have a 1956 235 engine in my 48. Thanks.
http://i1022.photobucket.com/albums/af342/scotphotobucket/yf2101S1.jpg
http://i1022.photobucket.com/albums/af342/scotphotobucket/yf2101S2.jpg
It looks like an automatic choke that would have a metal tube from the port on the carburetor to a metal "stove" that is wrapped around the exhaust manifold.
"Universal" choke stoves are available.
Thanks, Tim, I will order the part and see if it works.
Does anyone here have one installed so I can see the best way to install?
yes, thanks, I can do that. !
