BUSY BOLTERS Are you one? The Shop Area
| | Click on image for the lowdown.
| | Forums66 Topics126,777 Posts1,039,270 Members48,100 | Most Online2,175 Jul 21st, 2025 | | | Joined: Apr 2014 Posts: 72 Wrench Fetcher | Wrench Fetcher Joined: Apr 2014 Posts: 72 | when I got my Offy 2x1 and insulators, they only came with one gasket. I called Patricks and they advised me to only run a gasket between insulator and carb, what do you guys think? Im afraid of an air leak between the manifold and insulator. | | | | Joined: Mar 2002 Posts: 9,112 'Bolter | 'Bolter Joined: Mar 2002 Posts: 9,112 | I am under the impression that it is the correct way to do it. I only have the one under the carb.
| | | | Joined: Feb 2014 Posts: 215 Shop Shark | Shop Shark Joined: Feb 2014 Posts: 215 | What is the face of the insulator made from....fiber? If so you shouldn't need another gasket. If it is hard phenolic or such, you would need a gasket. Some spacers had gasket facings on both sides. | | | | Joined: Apr 2014 Posts: 72 Wrench Fetcher | Wrench Fetcher Joined: Apr 2014 Posts: 72 | It's a hard phenolic spacer. | | | | Joined: Feb 2014 Posts: 215 Shop Shark | Shop Shark Joined: Feb 2014 Posts: 215 | It needs a gasket on both sides then. | | | | Joined: Aug 2012 Posts: 1,214 Shop Shark | Shop Shark Joined: Aug 2012 Posts: 1,214 | On my 49 216 I only have 1 gasket between the Rochester B carb and insulator and no gasket between the insulator and manifold. Thats the way it was when I disassembled the topend. I thought it odd that it didn't have a gasket between the insulator and manifold but since the kit didn't include 2 gaskets I reassembled it the way I found it. Works great w/no vacuum leaks. | | | | Joined: Apr 2014 Posts: 72 Wrench Fetcher | Wrench Fetcher Joined: Apr 2014 Posts: 72 | Does anyone know where I can get a thin carb gasket? I had to pull the studs up just to fit this gasket and insulator, I'm not sure how much more stud I have left. | | | | Joined: Sep 2001 Posts: 29,262 Bubba - Curmudgeon | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,262 | Make your own out of cardboard or manila paper. Or, simply use a gasket sealer (without a gasket) under the insulators.
| | | | Joined: Oct 2012 Posts: 182 'Bolter | 'Bolter Joined: Oct 2012 Posts: 182 | Stock intake manifold is cast iron. Insulator face mating against intake manifold is phenolic.
Carburetor base is cast iron (at least with the W-1). Insulator face mating against carburetor is phenolic.
Same type of interface. Same materials. What reason is there for one interface to use a gasket and the other not? | | | | Joined: Feb 2014 Posts: 215 Shop Shark | Shop Shark Joined: Feb 2014 Posts: 215 | Any parts store should stock either small sheets or large rolls of gasket materials. You want a fiber sheet (vegetable or cellulose) with a nitrile or butyl binder. Comes in thicknesses down to 1/64". | | | | Joined: Mar 2002 Posts: 9,112 'Bolter | 'Bolter Joined: Mar 2002 Posts: 9,112 | The factory assembly manual doesn't show a gasket at all, just the spacer. | | | | Joined: Feb 2014 Posts: 215 Shop Shark | Shop Shark Joined: Feb 2014 Posts: 215 | The factory spacer would have had fiber facings on it. Nobody used a phenolic spacer with no facings for a carb mounting. OEM phenolic spacers were made with the facings bonded on. The aftermarket sells lots of spacers of phenolic that have no facings, and in this case, they probably assumed you had the original gasket, and therefore supplied only one.
| | | | Joined: Jan 2001 Posts: 5,320 'Bolter | 'Bolter Joined: Jan 2001 Posts: 5,320 | I have been working on 216 and 235's regularly for 50 years and I have never seen any kind of bonded facing or a gasket between the spacer and the manifold on a unmolested engine.
See the USA in your vintage Chevrolet! My Blog | | | | Joined: Feb 2014 Posts: 215 Shop Shark | Shop Shark Joined: Feb 2014 Posts: 215 | Pre '68, Phenolic or fiber spacers? A lot of the spacers were fiber core with laminated facings, and the whole thing encapsulated in a nitrile coating. | | | | Joined: Sep 2001 Posts: 29,262 Bubba - Curmudgeon | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,262 | Thanks, Dave,
I've only been playing with these engines for about 45 years, but not professionally, like you.
I also do not recall needing a gasket under any type of spacer, unless the intake manifold was pitted?
| | | | Joined: Apr 2014 Posts: 72 Wrench Fetcher | Wrench Fetcher Joined: Apr 2014 Posts: 72 | | | | | Joined: Feb 2014 Posts: 215 Shop Shark | Shop Shark Joined: Feb 2014 Posts: 215 | Question, is the bottom of the phenolic cast smooth, or is it cored out or embossed? | | | | Joined: Apr 2014 Posts: 72 Wrench Fetcher | Wrench Fetcher Joined: Apr 2014 Posts: 72 | Yes the bottom is cast smooth. | | | | Joined: Feb 2014 Posts: 215 Shop Shark | Shop Shark Joined: Feb 2014 Posts: 215 | Interesting. I'm wondering if it gets too hot for the fiber material. | | | | Joined: Mar 2010 Posts: 10,059 Renaissance Man | Renaissance Man Joined: Mar 2010 Posts: 10,059 | This area is very easy to check for vacuum leaks with an UNLIT propane torch. Mount it without the not-called-for gasket and test for leaks. BTW, ALL carbs have some vacuum leaks. Otherwise you would not be able to move the throttle valve shafts. It is the major vacuum leaks that cause trouble. Carl
| | | | Joined: Feb 2014 Posts: 215 Shop Shark | Shop Shark Joined: Feb 2014 Posts: 215 | So I was dragged away from my computer last night. First, it is obvious that the lower gasket is not needed on these engines. I am thinking that any slight leakage would not be noticed, as you would cover it up when you adjust the idle mixture. These are pre-emission engines.
In the mid 60's emissions became the concern. Carbs were made as lean as possible. Evaporative emissions were an issue. Not only could you not have leaks from an unsealed joint, you could not even have leaks from the permeability of some of the gasket materials. The fuel system gaskets were encapsulated to seal the surfaces and cut edges. This led to problems from sticking the flanges together, so a release coat was added over the encapsulant. Materials such as mica or Teflon were used. Teflon was easy to add dyes to, so various packagers and distributors wanted their products color coded. That's how we ended with Holley float bowl gaskets being blue, while others chose green or red, as can be seen in performance parts catalogs today.
In 1968 VW introduced the Kammbach station wagon with EFI, and that was the first nail in the coffin for carburetors and the emissions problems they caused.
| | | | Joined: Oct 2006 Posts: 9,671 'Bolter | 'Bolter Joined: Oct 2006 Posts: 9,671 | I'm on the side of Dave and Tim, never saw one with a facing on it, and I sold them back in the 50's-60's as a Chevy parts man. The original insulator was a similar to a Phenolic 'Laminate' which had a slight amount of give to it. They probably used a cotton filler or possibly asbestos so that it had enough give that when it was sandwiched between the two machined surfaces of the cast iron carburetor and cast iron manifold, it would conform to the very small imperfections on the surfaces. The reproduction ones sold by the vendors today as a replacement appear to be phenolic also because it can take the heat, but they just use a filler such as carbon black or clay in the compound and are not a laminated part. This makes them hard like the old phenolic (Bakelite) radio cases and electrical components are made from. Because of the material that the new insulators are made from, I use a standard gasket both on the top and the bottom. I personally feel that for proper operation, there should be no vacuum leaks where the fuel/air mixture is concerned.
Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | Joined: Feb 2014 Posts: 215 Shop Shark | Shop Shark Joined: Feb 2014 Posts: 215 | Yeah, the Bakelite type black phenolic material is what I was referring to. It's just a molded part. That's why I was surprised that they didn't use a gasket. All the ones we manufactured in later years for OEM and aftermarket had bonded facings. We purchased the phenolic cores from various vendors. | | |
