6 members (Hotrod Lincoln, klhansen, Mike B, Otto Skorzeny, IHPWR, Jims46), 50 guests, and 2 robots.
Topics128,030
Posts1,055,423
Members48,422
#104650 12/08/2003 6:28 PM
Junior Member
Junior Member
I am considering using a composit wood (Timber Tech) in my bed. Has anyone done this before, and any comments on this idea?
"Boop-Boop-a-doop"
#104651 12/08/2003 7:01 PM
Never heard of it being done but I think it's an idea that which's time has come. I'd be real interested in knowing how it works out ...
#104652 12/08/2003 7:23 PM
Rayman,
I addressed this same question back in August ( Plastic Bed Wood )
I did some research on this idea a few years back. Contacted all of the manufacturers and got data sheets, etc. The only problem with using plastic lumber is that it tends to sag if the space between supports is too large. Using 3/4" lumber (which would match the thickness of the original bedwood) you need supports on a maximum of 16" O.C. (12" O.C. recommended by some manufacturers). The space between the bed sill supports is much greater than this. If you don't have adequate supports, your bed boards will sag between the supports. If you could work out some system of additional support on the underside, I think plastic lumber would make a dandy bed.
Jeff Nelson
"Beer is proof that God loves us and wants us to be happy." - Benjamin Franklin
"Always do right. This will gratify some people and astonish the rest." - Mark Twain
#104653 12/08/2003 7:23 PM
The problem with those products is when water penetrates. If you can keep all edges properly sealed it should give a very hard and wearable surface. Could paint it black for the original look.
54 3100 with 235
62 flatbed dump C60 with 261
#104654 12/08/2003 7:35 PM
Tony,
Timber Tech is one of the new breed of plastic composites, used quite extensively for decks and outside furniture. There is little to no water absorbtion by these products. I think you might be thinking of the wood composites (e.g. "particle board") that will have the water absorbtion problem.
Jeff Nelson
#104655 12/08/2003 7:55 PM
Another thing you should think about is that the decking size planks of most of the synthetic material is what we call "5 quarter" and is clost to 1" thick. You need access to a thickness planer as well as a table saw (or router) to machine the rabbets in the sides. Lastly the width sizes in the stuff I've seen is limited. It's worth thinking about because of the movement associated in using wood in an outside environment is a real pain.
John Atherton
Wichita Forest Woodworks
I know you believe you understand what you think I said, but I'm not sure that you realize that what you heard is not what I meant!
#104656 12/08/2003 8:05 PM
Oh I see, plastic. Does it come in black?
54 3100 with 235
#104657 12/08/2003 8:24 PM
As John stated, most of the manufacturers only produce 5/4" decking. A few do produce dimensional lumber, but even those manufacturers appear to only have one or a couple of nominal 1" (3/4" actual) sizes. One manufacturer, Plastic Lumber Products , sells 1" x 6" but no other sizes.
In answer to Tony's question, yep, it comes in black. Here's a link showing colors and sizes of the dimensional lumber from Plastic Lumber, Colors & Sizes
Do a Google search on "plastic lumber" to get lots of manufacturers and distributors.
On last point, if you do use it for bedwood, make sure you have the stock, under-bed heat shield installed. Otherwise you will probably melt a nice hole through the bed. grin
Jeff Nelson
#104658 12/08/2003 10:15 PM
For perspective...Last year I re-did my deck at the NJ Shore with composite decking, it looked (and still looks)terrific, but I put it on 16" centers and it did sag(even without anybody walking on it). Secondly, even though it's plastic...it is still quite pourous and it gets dirty and...it takes a power washer to really clean it. It is also quite heavy(much heavier than comparable sized lumber) and difficult to drill.
I would think that if you wanted to do something beautiful, different and long lasting consider Mahogany (actually less expensive than some composites).
Good luck
Steve G.
1942 Chevrolet 1/2-Ton Pickup Truck
