4 members (baldeagle, treegrower, Gdads51, 3B), 94 guests, and 8 robots.
Topics128,014
Posts1,055,328
Members48,419
Yesterday the brake pedal started to make a loud clunk when returning to the rest position, on my '55 2nd 3100 pickup. Then I noticed that the brake lights were on all the time. I see that the actuation arm on the brake light switch is missing now. Is there something other than the switch actuation arm that stops the brake pedal arm in its travel back up to the firewall? I have a new Standard parts switch on the way from Rock Auto.
you can get those switches at NAPA, Standard SLS43 or ColeHersee 8487 .... originally there was only a 'stop' bumper on the clutch pedal arm, like this, you could put one on the brake pedal arm, but if everything is positioned properly it shouldn't need it, the pedal doesn't push the switch arm far - maybe your connection to the master cyl needs adjusting or maybe the switch just fatigued
Many Thanks, Bill, My local NAPA, a couple miles away, had the switch (NAPA/ECHLIN #SL132) in stock. I'll have the one from Rock Auto as a spare.... The '55 is pretty much my daily driver, and now I can have it back on line tomorrow early AM. The switch arm is swaged onto the shaft, is must have worn and then slipped off.
