8 members (FAST55, rfs56trk, 3B, Shade Baby, Hanks custodian, Wally / Montana, Otto Skorzeny, Donf), 45 guests, and 1 robot.
Topics128,038
Posts1,055,584
#1046079 07/31/2014 4:09 PM
1 Offline
So I'm in the process of taking apart the box on my '42 and have just about every bolt off when I realize the metal strip that holds wood to the box seems to be rusted and possibly fused to the side wall. Has anyone had this happen? And if so what are some possible solutions to separating the two?
1942 BK 1/2 Ton Pickup
1954 3800 1 Ton Pickup
Are you talking about the angle strips that run the length of the sides? If so, then these are spot welded on. You have to drill the spot welds to remove. You can find replacements at Mar-K.
Dennis
40 Chevy 1/2 ton
1 Offline
Oh that explains it. I'll have to look again when I get home however how would I be able to spot these spot welds? Are they noticeable? Thanks
yes the spot welds are noticeable, fairly evenly spaced slight dimples
