7 members (Otto Skorzeny, Southerntruck, Guitplayer, Hotrod Lincoln, 52Carl, qside, 1 invisible),
160
Mod | | | Forums66 Topics128,087 Posts1,056,115 Members48,435 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2013 Posts: 367 Shop Shark | | Shop Shark Joined: Oct 2013 Posts: 367 | As I go about assembling everything I have there's this new puzzle. The frame is a '49, everything else is from a '50 3100. Here's a pic of the core support: http://i.imgur.com/9WyJOl4.jpgDoes this support accommodate both the center mount and the side mounts? The frame only has the center holes and I am wondering which supports to buy. | | | | | Joined: Oct 2009 Posts: 164 'Bolter | | 'Bolter Joined: Oct 2009 Posts: 164 | If the cross member that supports the radiator support matches i would by the center one. | | | | | Joined: Oct 2013 Posts: 367 Shop Shark | | Shop Shark Joined: Oct 2013 Posts: 367 | This was my mistake. The frame is a '49 3100 but the core support is from a '50 3600.
The mount, as pictured, is in pretty bad shape and both bolts are rusted to/in it.
Is there any harm in using the two side holes and drilling these holes in the cross member? Seems like a much beefier and sturdy alternative. | | | | | Joined: Oct 2013 Posts: 367 Shop Shark | | Shop Shark Joined: Oct 2013 Posts: 367 | | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Fix and use the one you have. The 50 has perches ...pic... Early mount... ...pic... ...pic... | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | The center mount is part of the whole design to allow the frame to move without affecting the front clip. Those spacers are used to adjust the sheet metal for a good fit. | | | | | Joined: Oct 2013 Posts: 367 Shop Shark | | Shop Shark Joined: Oct 2013 Posts: 367 | Got it. I didn't know the other had perches. | | |
