| | | Forums66 Topics128,113 Posts1,056,279 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2013 Posts: 137 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2013 Posts: 137 | Wipers work but pretty slow. Any suggestions for improvement? Probably won't see much rain but in case?
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | should have multiple speeds, either the motor or switch needs attention
Bill | | | | | Joined: Feb 2014 Posts: 215 Shop Shark | | Shop Shark Joined: Feb 2014 Posts: 215 | Slow wipers and a goofy temperature gauge? Anything else acting up? Have you checked the voltage available? | | | | | Joined: Oct 2013 Posts: 137 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2013 Posts: 137 | Have not checked voltage available, but everything else seems normal. There are a lot of extra wires with single in-line fuses; I'm assuming something to do with Camper Special?? Where is best place to check voltage available - each instrument, or one single point? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | if the starter works well, and the headlights work properly, the problem is not "voltage available" unless you have a really poor connection at the wiper or switch, in which case that connection will be getting very hot .... does moving the switch give multiple speeds?
Bill | | | | | Joined: Feb 2014 Posts: 215 Shop Shark | | Shop Shark Joined: Feb 2014 Posts: 215 | You can start at the fuse block. Look for the correct fuse. Work your way up to the panel or wiper switch itself where the 12V comes in. Check at the individual gauges, or wiper motor. For any electrical issue, take it step by step. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Farmone and guys, The wiper motor has power with the ignition switch in run or accessory position, the switch provides ground to the circuit, so make sure the switch is grounded to the dash and the cab has a good path to ground, hope that helps. | | | | | Joined: Oct 2013 Posts: 137 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2013 Posts: 137 | I cleaned and lubed the linkage and got a significant improvement, but no difference in wiper speed between low and high. I think I will replace the switch | | |
