1 members (Hotrod Lincoln), 104 guests, and 2 robots.
Topics128,089
Posts1,056,004
Members48,430
I'll pulled the carburetor today and had to laugh when I pulled in the intake pipe and found what appears to be a mouse nest or some other debris in the carburetor and partially up through the intake tube.
Nest in carburetor
I'll probably be hunting for a re-built carburetor rather than try to work on this myself. Anyone have any sources for these updraft carburetors?
Bob
1954 Chevy 3100 5-Window
1954 5-Window COE aka "THE BEAST"
Bill Ritchie's Original Truck
Granddad's Hardware Store: Ritchie Hardware, Concord, N.C.
Bethesda, MD
Carburetion specialist
Unless you are independently wealthy and do not wish to remain so, you would be better off rebuilding the carb yourself. wink
The carb should be a 2075s Carter.
I don't know if they are still in demand; but a few years ago, the guys racing Bugattis (yep, not a misprint) were scouring the earth for this carb.
I don't recall the exact model, but there is one model of supercharged Bugatti popular for vintage sports car racing that had a two-barrel updraft Solex that just wasn't popular. A company in the northeast developed some modifications for the 2075s making it compatible with the blower, and they replaced the updraft two-barrel Solex with two of the Carter 2075s.
Kits are readily available, as are most other components except for the castings and the main venturi. This was the largest of all of the BB updraft Carters.
I got your email, but then saw your question here, and thought others here might enjoy the story.
Jon.
The Carburetor Shop
Certain Solex carb seem to be hard to find any kits for.... I have a triple carb setup for a Saab 2 stroke and there doesn't seem to be squat around for them other than a gasket set.....
