6 members (TUTS 59, Ponchogl, Steelonsteel, Gdads51, Gray_Ghost, ESum), 92 guests, and 4 robots.
Topics128,088
Posts1,056,125
Members48,435
#1045240 07/27/2014 10:29 PM
The rear slip joint and hanger bearing on my driveshaft are worn out. Can I replace my driveshaft with a longer one and not use the center bearing?
3B Offline
Hy Sparky1, the engineers designed a driveshaft system that would give the least problems for the longest time, so I would just replace what has worn out rather than re-engineering the situation, hope that helps.
