2 members (Guitplayer, JW51),
148
Mod | | | Forums66 Topics128,087 Posts1,056,114 Members48,435 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2014 Posts: 34 New Guy | | New Guy Joined: Feb 2014 Posts: 34 | The rear slip joint and hanger bearing on my driveshaft are worn out. Can I replace my driveshaft with a longer one and not use the center bearing? | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Sparky1, the engineers designed a driveshaft system that would give the least problems for the longest time, so I would just replace what has worn out rather than re-engineering the situation, hope that helps. | | |
