5 members (Gray_Ghost, 49choptop, Guitplayer, pauld, Forty9), 101 guests, and 4 robots.
Topics128,201
Posts1,057,281
Members48,467
8
8 Offline
I recently bought a '34 1.5ton with a '52 216 motor. The original wiring harness has been removed, and I believe the generator and starter are off of the same '52. I want to order a new original style harness (that has the voltage cut out on the generator). My question is can I instal a voltage cut out on the generator that is currently on the truck? Or do the Voltage cut outs only work with specific generators?
Curt Warren
Salt Lake City
1948 1.5ton Loadmaster
http://photobucket.com/48loadmaster
the cutout is part of the early generator, if you have a 53 generator it requires the separate external voltage regulator, which shouldn't be too hard to wire up yourself - compare the wiring diagrams
red58 is correct. The original 1934 generator would have been a three brush generator with a cut out relay mounted on it. By 1952 they had gone to a two brush generator with a voltage regulator mounted on the fire wall most of the time. If you can post some pictures I can ID what you have or I can private message you my email address and you can send some pictures that way.
Ken
8
8 Offline
Here is the voltage regulator that is mounted to the firewall. This is the Generator that is on the truck.
The only thing I can make out on the generator is Delco 2A24
I appreciate the help gentleman!
Curt Warren
Salt Lake City
You have a later-model generator/regulator system than the vehicle had when it was manufactured, and it appears to be wired incorrectly. There should be two wires attached to the left side of the regulator as it shows up in the picture, armature and field, which will go to the generator. The third wire will be routed from the regulator to one side of the ammeter on the dash and from there to the battery cable terminal at the starter. You have an early version of the 3-unit regulator with three sets of coils under the cover, a cutout relay behind the battery terminal, a current regulator behind the Arm terminal, and a voltage regulator behind the Fld terminal. If you can get a model number from the regulator, I might be able to provide some adjustment specifications for it.
