3 members (49 panel, UtahYork, Nick in Manitou), 65 guests, and 2 robots.
Topics128,030
Posts1,055,428
Members48,422
#1044442 07/23/2014 10:58 PM
OK. I have my 235 stripped down (mounted on frame) and cleaned. So I can tape off thing I don't want painted and block holes (distributor, fuel pump) then spray the entire thing with etching primer and paint over the primer?
Need I have any concern for gaskets, etc?
jrdamien #1044447 07/23/2014 11:26 PM
You don't want any paint on gasket surfaces.If you're painting the engine you don't need etching primer.
Pete
jrdamien #1044448 07/23/2014 11:30 PM
you got a pix of it, replace with new gaskets
Redryder pix
My Hotrod
jrdamien #1044449 07/23/2014 11:31 PM
Gas Pumper
Gas Pumper
Just because its prudent, if you DO use primer, get high temp primer. I hear Dupli-color makes an engine primer for that purpose, but have never used it.
Deve
1950 Chevy 3100 Deluxe Cab
1950 Chevy 3100 Standard Cab
The Think Tank
jrdamien #1044452 07/23/2014 11:47 PM
Do it the proper, old fashioned way -
Get all surfaces super clean...clean with Acetone...
Heat with a Space Heater so the entire Engine is body temp or a little more..110 degrees is fine.
Use a good Grade Oil Base Industrial Enamel.
Add a little 'Pentrol' or similar to help keep a 'wet lap'.
'Mask' nothing, use a suitable good quality 1-1/2 inch wide Paint Brush...and, simply 'Paint' the Engine, one coat, no 'primer'.
Done right it will last forever, it is super easy to keep clean, Oil or Gasolene or other stains wash right off.
Bake for a week in the Hot Sun or with a Space Heater.
Done right, as described above...the result looks like 'Baked Enamel' and is gorgeous.
Pete52 #1044519 07/24/2014 5:43 AM
Pete
Well I don't mean the surface of the gasket that, say, joins the water pump to the engine. I mean the edge of the gasket - whatever of the gasket is exposed between surfaces.
Can this get paint on it?
jrdamien #1044520 07/24/2014 6:14 AM
Things look neater if Gasket Edges are free of Paint.
Otherwise, it will not hurt anything if they are painted.
jrdamien #1044548 07/24/2014 1:14 PM
As stated you said the engine was stripped down what I said you don't want to paint were the gaskets are going to be, say were the water pump is going to be installed I mask all that off so I have bare block on the gaskets.
Pete
jrdamien #1044598 07/24/2014 5:15 PM
Correct - Gaskets need to be applied to clean, bare Steel/Iron.
jrdamien #1044603 07/24/2014 5:38 PM
The original and therefore the proper way is to paint the engine in the assembled state. This ensures that the gasket mating surfaces have no paint and that the gasket edges do have paint. This also ensures that there will be no chipping of paint caused by lockwashers during the installation of the fasteners holding on the sheet metal parts etc. Its also hard to install painted fasteners without chipping them.
Paint on the edges of cork and thick fiber gaskets is good since it reduces oil seepage through the gasket material
Sput #1044611 07/24/2014 6:31 PM
Nice. This is what I was getting at.
jrdamien #1045826 07/30/2014 7:17 AM
For those curious, here it is (sans valve cover) after a can of grey.
http://i.imgur.com/wRu3zW7.jpg
jrdamien #1045835 07/30/2014 12:45 PM
Looks good
jrdamien #1045840 07/30/2014 1:15 PM
Nice work! Looks awesome
1954 Chevy 3/4-Ton Chevy
"Mo"
1948-53-54 "Mixed Bag" Chevy Stakebed
"Basket Case"
1952 Chevy 3/4-Ton
"as yet un-named"
Lots of pictures
jrdamien #1045841 07/30/2014 1:15 PM
What did you end up using paint-wise?
"Mo"
"Basket Case"
1952 Chevy 3/4-Ton
"as yet un-named"
Lots of pictures
jrdamien #1045882 07/30/2014 7:07 PM
I just used Duplicolor engine primer. I do believe the exact color is Ford Gray. smile
But I wanted some blue in the gray.
jrdamien #1045909 07/30/2014 9:00 PM
U
U Offline
Looks great! I hope to be picking out engine color/shade in a couple of weeks.
Thanks for putting up the picture. It helps to see it fresh on an engine as opposed to looking at a cap color.
Brad
Wrench Fetcher, PhD
Uncle Brad #1045915 07/30/2014 9:20 PM
Brad
Yes it does and this is lighter than I thought it would be, but it's also wet. I'll get another shot of it dry tomorrow.
